Carb jetting
  • Burky
  • Burky's Avatar Topic Author
Carb jetting
24 Apr 2008 18:45
#208846
Need some advice,
I bought a 1979 KZ 100 Ltd. 6 months ago. It has I was told by previous owner 29mm smoothbore's with the k&n pod filters. It also has a 4 into 1 exhaust. I want to put the original 4 into 2 system back on it. Do I need to change the jetting? Is it a possibility it would run ok by just putting the 4 into 2 back on it.If it does need different jetting where do I find information on what the appropriate jetts are? Any help would be greatly appreciated.
Burky
  • Qdude
  • Qdude's Avatar
  • It is all good.
Re: Carb jetting
24 Apr 2008 20:15
#208876
Wouldnt there be stock jet sizes in the Clymer manual?
77 KZ 650 C1.
77 KZ 650 C1.
  • wiredgeorge
  • wiredgeorge's Avatar
Re: Carb jetting
25 Apr 2008 05:43
#208933
VM29 smoothbores are aftermarket carbs and won't be in a Clymers. I rejet about 20 sets a year. With pods and 4 into 1 or 4 into 2, should not make a lot of difference. First check to ensure that you have 1.5 slide cuts outs. They sold 3 different models of the VM29 and the 1.5 slide cut out was what was intended for the large displacement (903/1015) KZ/Z1. This small slide cut out has relatively fast air speed at idle so you can use smaller pilot jets. I use either #17.5 or #20 pilot jet. With the #17.5 you only need to turn out the air screws about 1/8 turn out from lightly seated and with the #20s about a half turn out. Both pilot jet / air screw set ups will give you a smooth, clean idle. The jet needle/needle jet combo is on the rich side, so with your set up (stock engine), I would clip to third slot (5DL31-3) and use around #120 main jets. The Mikuni recommended settings you will find posted on the internet don't work well and they don't even say whether the settings are for modified bikes, bikes with modified airboxes or pipes, etc.
  • Burky
Re: Carb jetting
26 Apr 2008 10:14
#209236
wiredgeorge,
Thank you for the helpful information. I printed it and I'll go from here. I don't know if I will be able to do this myself if it needs done but I'd like to try. Do you know of any good books or references to get to help me? I will surely come to your company if I need carb work done.
Thanks alot,
Burky
