Throttle Cables routing
- SebRain77
- When in doubt, gas it!
23 Apr 2008 18:07 #208567
by SebRain77
Ever hit the pavement? I did, put that gear on!
1977 KZ 650C1 - First bike, ever! For sale - or not!?!?
2004 Z750 - More power than I'll ever need...
Gatineau, Qc, Canada eh!
Throttle Cables routing was created by SebRain77
Ok, here's the deal. I changed my throttle cables for new ones. Was convinced the bike was a 650C1. Wich it is, except for the handlebars, they dont go up much, and the signals are affixed to them, not attached to the headlight.
Is there a right or wrong way to route those cables? I wouldn't think so, as long as the throttle doesn't increase or decrease when turning, right? And I don't really want to have the cables run in front of the right signal for obvious safety reasons! I looked at the pictures in the 650 gallery, and routings are all over the place.
I know some of you have this knowledge! Thanks in advance!
- Bluemeanie
- Thank you received: 14
23 Apr 2008 19:21 - 23 Apr 2008 19:22 #208587
by Bluemeanie
Replied by Bluemeanie on topic Throttle Cables routing
Pretty strange that you have a C1 with signals attached to the handelbars but here is the routing for my F1. (remember to click to enlarge)
Last edit: 23 Apr 2008 19:22 by Bluemeanie.
- bill_wilcox100
- Thank you received: 5
23 Apr 2008 20:37 - 23 Apr 2008 20:39 #208612
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Throttle Cables routing
Upgrades:
Montreal, Canada
Last edit: 23 Apr 2008 20:39 by bill_wilcox100.
- SebRain77
24 Apr 2008 05:42 #208683
by SebRain77
Replied by SebRain77 on topic Throttle Cables routing
I figured something was different when I noticed there was a low fuel warning light in the tach! The only thing that worries me a little bit is routing the cables that way, they will pass right in front of the right signal... So I had them routed behind the signal, attached to the handle bars, and then behind the headlight and then just the normal routing. I'll see if the throttle works right just this way, otherwise I'll have to find another routing or change the handlebars... Something like drag bars maybe... We'll see in due time.
Thanks guys, really appreciated!
- PLUMMEN
- Thank you received: 104
24 Apr 2008 05:48 #208684
by PLUMMEN
Replied by PLUMMEN on topic Throttle Cables routing
depending on what bars you are using i run mine between the hedlight bucket and headlight bracket;)
- SebRain77
26 Apr 2008 06:18 #209199
by SebRain77
I kinda figured out a way that doesn't obstruct the right signal. I don't think many people will notice. Hey, as long as its safe and it does the job right!
Now all I need to do is clean the gas tank and install the fuel system hoses and we'll be riding! Can't wait:woohoo:
