- Thank you received: 14
new member 81 kz750e four
- Bluemeanie
20 Apr 2008 09:31 - 20 Apr 2008 09:32 #207817
by Bluemeanie
Replied by Bluemeanie on topic new member 81 kz750e four
This is how I did mine, works good. Take your time and get it right. (remember to click on image for larger pic)
Last edit: 20 Apr 2008 09:32 by Bluemeanie.
- DanAir
21 Apr 2008 00:33 #207945
by DanAir
Replied by DanAir on topic new member 81 kz750e four
Our carburetors (81 KZ750E-2) have the sync adjustments outside of the carbs on the linkage, front end. You may be able to get them close with a wire as a gauge, but I used a low side refrigeration gauge (adapted with hose) and adjusted them one carb at a time. Took a while, but now they are exactly the same. Runs perfectly. Cleaned them TWICE first.
Don't separate the carbs from each other for cleaning. I used 2+ spray cans of carb cleaner. Dollar store was cheap.
Good luck with it and welcome to KZR.
Let us know how it's going.
- DanAir
21 Apr 2008 00:39 #207946
by DanAir
- JMKZHI
- Thank you received: 48
21 Apr 2008 04:57 - 04 Dec 2008 06:07 #207954
by JMKZHI
Replied by JMKZHI on topic .
del.
Last edit: 04 Dec 2008 06:07 by JMKZHI.
- mls81kz750e
29 Apr 2008 12:00 #210066
by mls81kz750e
1981 kz750e: lowered rear, sportster style fender, changed headlight, no controls on bars,
Replied by mls81kz750e on topic new member 81 kz750e four
got it all cleaned out and she's running strong. One of the overflow tubes is cracked on the #1 carb so its leaking pretty good, but its alive. It did feel like solid till I got the strand of wire through it and then put the hose with carb cleaner in it and shot it clean. I used a piece of wire and did a bench sync, started on the first try. My starter clutch is about done but it starts as soon as I touch the button.
- wiredgeorge
29 Apr 2008 12:23 #210074
by wiredgeorge
Replied by wiredgeorge on topic new member 81 kz750e four
Buy some JB Weld and smear some over the crack. It fixes the crack permanently.
- bhart0228
17 Nov 2011 18:28 #488977
by bhart0228
1978 KZ400
1985 VFR700r
1977 BMW R100/7
1981 KZ750e
Replied by bhart0228 on topic new member 81 kz750e four
I've got a 1981 KZ750e and would like to know where you got the 1/4 fairing and what brand is it. Any mods on the install
1978 KZ400
1985 VFR700r
1977 BMW R100/7
1981 KZ750e
