Carb Vacuum Hoses
- BIGD
17 Apr 2008 13:56 #207200
by BIGD
Had 1981 KZ1000 M1 From 1981-1995 Canadian Model
Have 1981 KZ1000 M1 US Model
Carb Vacuum Hoses was created by BIGD
The bike in question is a 1981 KZ1000M1(US Model). I have noticed while doing another repair that my #3 carb has a single rubber stopper over top of the vacuum part.My #1 and #4 carbs have a vacuum hose into a 3 way which leads to the vacuum switch valve(correct according to manual) and the #2 carb has the vacuum hose connected to the fuel tap(correct according to manual) but it does not say if #3 carb is attached to nowhere. Thanks if someone can tell me if this is correct for #3 carb. Thanks BIGD
1981 KZ1000M1
Toronto, Ontario Canada
1981 KZ1000M1
- wiredgeorge
17 Apr 2008 15:17 #207226
by wiredgeorge
Replied by wiredgeorge on topic Carb Vacuum Hoses
The #3 vacuum cap is correct. #2 to the petcock and the #1 & #4 are tied and go to the vacuum actuated switch that opens your reed valves on the valve cover.
- BIGD
18 Apr 2008 16:24 #207452
by BIGD
Replied by BIGD on topic Carb Vacuum Hoses
Thank You. BIGD
