Float Height (29mm Smoothies)
  • Sandy
  • Sandy's Avatar Topic Author
  • Fly High,Tony
15 Apr 2008 21:39
#206811
Well so much for using the "Search" function.What the hell is up with it,anyway?
I tried a whole list of different words and phrases,but nadda!:angry:
Sometimes I really miss the OLD KZrider.The search function worked.:(
Anyway...it's past my bedtime apparently(I'm bitchy),but before I go...
Float Height on the 29 Smoothies.I'm PRETTY sure it's 24mm,but is that WITH,or WITHOUT the bowl GASKET in place?
It's been a long time since I've had to know that...DUH!:laugh:
Thanks Guys.B)
(Oh...and any tricks on USING the search function would be helpful.There's not just ONE tab to do a search,there's a couple...wtf?)
1977 KZ1000 A-1
  • Sandy
  • Fly High,Tony
Re: Float Height (29mm Smoothies)
16 Apr 2008 20:06
#207032
Thanks for the help,but I got it all figured out.
You guys were a great help:P
1977 KZ1000 A-1
  • racer54
  • racer54's Avatar
16 Apr 2008 22:25
#207065
Well....what is the float height for smoothbores? Whatcha find out? Like to put this in my files.
  • Sandy
  • Fly High,Tony
17 Apr 2008 07:57
#207095
23mm from the base,WITHOUT the gasket.;)
1977 KZ1000 A-1
  • Jack
  • Jack's Avatar
17 Apr 2008 12:43
#207180
Greg Cope published this list of tips for 29's a while back:
Float level- 23.5-24.5 mm. from base of gasket to top of float.
#0-4 Needle Jets
#1.0 Air Jets
#2.5 Needle/seat
Hope this helps.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • wiredgeorge
  • wiredgeorge's Avatar
17 Apr 2008 15:23
#207229
I think 23mm measurement is without the gasket in place. Best to use the 23mm with no gasket since there are a variety of gasket papers used (different thicknesses). The needle jet is 0-6 by the way. The needle/seat thing stated as #2.5 is misleading. What the 2.5 is is that the hole size in the float seat which is 2.5mm and last, the stock air jet on all varieties of VM29 is .9 that is .9mm - I think you can buy 1mm air jets but difference in size wouldn't make a difference, to my thinking. The larger air jets are used because the slide cut away is 1.5 which is about the smallest available on the Kaw version of the VM29. I think that 1mm air jets are the standard on a VM33...
  • racer54
  • racer54's Avatar
18 Apr 2008 12:20
#207413
All good information to have and stash in bike notes. My bike and carbs thank you.
