No fuel in #1 Cylinder
  • BoZ650
  • BoZ650's Avatar Topic Author
  • 77 KZ650 with 4 to1 and pods,Dyna Coil and Dyna S
15 Apr 2008 15:07
#206724
Looking for help.I have a 77KZ650 with a 4into1 header,air pods,dyna coils and ignition.Im having problems with the #1 cylinder not getting fuel.Ive had the carbs off many times now and ive cleaned them out just as many times.Now the original problem was the # 3 carb getting no fuel After one of my cleaning sessions I fixed that and now # 1 is out.Looking for any advise you can offer!Thanks
Tony
77 KZ650 With 4 into 1 header,Air pods,Dyna Green coils,Dyna S Ignition and WiredGeorge coil mod!
  • bountyhunter
  • bountyhunter's Avatar
Re: No fuel in #1 Cylinder
15 Apr 2008 16:20
#206734
Check compression to make sure the cylinder is pulling.
Check fuel down to the carb by opening the drain screw.
Check the float levels.
Make sure the filters are clean.
  • rdgrnr
  • rdgrnr's Avatar
15 Apr 2008 16:24
#206737
sticky needle and seat? Did you have them out and switch them to #1?
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
