20 pilots
  • vach
  • vach's Avatar Topic Author
20 pilots
11 Apr 2008 10:26
#205740
is anyone else running 20 pilots on a 650? if i run 17.5's and crack the throttle it's hesitating. the 20's takes it away. however i don't have a response in engine fluctuation when i turn the #1 cylinder air screw. i can pull it all the way out or turn it all the way in w/no response. could this be why i'm having to run 20's?
1979 kz650 B. Chicago, Illinois
  • bountyhunter
  • bountyhunter's Avatar
Re: 20 pilots
11 Apr 2008 13:39
#205789
Maybe... sounds like #1 is getting all the air it wants from a source other than the bore of the carburetor?
Are you sure the carbs are synced and balanced? You might have one not doing much at idle and would give the same symptom.
  • vach
Re: 20 pilots
11 Apr 2008 14:01
#205796
yeah, they're all at 10hg. the # 1 cannot be adjusted w/ the air screw. definitely no vacuum leaks. maybe something in a passage way in that carb.
