Plug came off of carb holder tube - will this hurt performance?
- elcid
10 Apr 2008 23:59 - 10 Apr 2008 23:59
Check the diagram here:
go to number 16 & 17. I lost this rubber cap. Will this hurt performance? What are these tubes for any way??
Last edit: 10 Apr 2008 23:59 by elcid.
- Mcdroid
- Gone Kwackers
Re: Plug came off of carb holder tube - will this hurt performance?
11 Apr 2008 00:28
They are for hooking up external vacuum gauges to check the balance between your carbs...and yes, those ports need to be blocked at all times (either with a vacuum gauge or the plugs) (Z1Enterprises sells them individually).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- JMKZHI
Last edit: 04 Dec 2008 05:54 by JMKZHI.
- BSKZ650
11 Apr 2008 05:19
as a temp fix you can get vaccum plugs at the parts store
77 ltd1000, current rider
76 kz900, just waiting
- Z1109R Fin
11 Apr 2008 05:40
On the other hand you´ll get cruise control since revs won´t go down:P No, seriously, teh must be closed all times otherwise the air/fuel -mixture goes nuts and it runs like crap.
Z1000R ´83...Slightly modified...
- wiredgeorge
11 Apr 2008 05:47
I wouldn't run a bike with a cap missing. Makes that cylinder run REAL WARM!
- elcid
11 Apr 2008 09:36
I was wondering my bike starting running crappy! I just had the carbs retuned a few weeks ago & it was running so smooth. Then I noticed some "weirdness" & thought man they go out of sync that soon?? Then I looked & saw one of those rubber caps missing. It didn't dawn on me until yesterday that that could be the cause. I went down to home depot & got this cap & put it on there. And BAM it runs smoothly again! YES! But do I need the exact ones from Z1 that are made for that purpose or can I use any rubber cap that seals it?
- RonKZ650
11 Apr 2008 09:56
Better get the right kind, made for gas. I'd bet Home depot rubber with get saturated with gas before the day is over.
- elcid
11 Apr 2008 10:25
couldn't I get something like that from an auto parts store?
- RonKZ650
11 Apr 2008 11:57
elcid wrote:
Probably, otherwise in a pinch you can use a short hose plugged with a bolt or something to that effect.couldn't I get something like that from an auto parts store?
- Duck
- e vica na i sau na ga
11 Apr 2008 18:28
elcid wrote:
-duck
Keep riding without the plug and you'll be replacing at least a piston...I lost this rubber cap. Will this hurt performance? What are these tubes for any way??
-duck
- elcid
11 Apr 2008 19:39
Got some caps from my local Autozone. They're made by "vacu-tite" so I hope they will work. Time will tell...
