- Thank you received: 12
I broke the damn Petcock valve............but i fixed it
- oldkaws4ever
- Have no regrets...... You only live once.
10 Apr 2008 00:48 #205363
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
I broke the damn Petcock valve............but i fixed it was created by oldkaws4ever
When i was leaving work tonight i went to flip my petcock to the reserve posistion ( i didnt have time to stop and fuel up before work), anyways the little arm that turns the petcock on and off snapped right in half:angry: . So i used a pair of plyers to turn it on and off. I was kind of freaking out, cause i didnt know how to fix it, but then i remembered i had the original petcock at home in the garage. When i got home i switched out the little arm and sprayed it down with wd-40 to keep it moving smooth. Im good to go nowB) :lol: :silly:
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Qdude
- It is all good.
10 Apr 2008 09:39 #205427
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic I broke the damn Petcock valve............but i fixed it
I am using a GS vacume petcock. It has a huge filter screen on it.
77 KZ 650 C1.
77 KZ 650 C1.
- Locozuna
10 Apr 2008 09:43 #205430
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic I broke the damn Petcock valve............but i fixed it
WD is cool but I would prolly use a little grease too. I find that WD does not last. It's more of a cleaner and is temp as a lube. I think the little O=ring would do better with a greasing. Not heavy just a little skim.
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- oldkaws4ever
10 Apr 2008 09:52 #205434
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic I broke the damn Petcock valve............but i fixed it
thanks locozuna, ill go out in a bit and put some grease on the o ring.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
