Does that seem excessive?
I turned the screws out 2 n a half turns and the Rpm went up about 600. I've read that this is a way to rough tune the screws. This is as far as I have ever had them out, and I am a little concerned.
Do I run the risk of being too lean here?
Should I run it this way for a while and check the plugs later for indication of problems?
They are no pump Mikunis.
77 KZ 650 C1.
77 KZ 650 C1.
