Only runs on starting fluid?
- Handegard
08 Apr 2008 19:56 #205122
by Handegard
1982 GPz550 H1
stock, except pod filters
Only runs on starting fluid? was created by Handegard
So, I've dusted the '82 KZ550H1 off for another summer of hoping to make it go. Long story short, I had a set of carbs from a later model bike, and I traded them to someone on here who had the opposite problem, and my bike has never run since.
After everything I've done, I now have the bike sitting in my garage, and it fires right up with a little starting fluid. After that, it dies. Does this with or without choke. I have fuel flowing freely to all the carbs, I can get a little fuel out of the bottom of each by losening the screw on the bottom. I just put in a good tank of fuel.
I've had these carbs apart more times than I care to think about. I just don't see anything clogged.
What am I missing? It's a fuel problem, I've narrowed it down to that. I don't have a extra set of carbs laying around either.
1982 GPz550 H1
- vach
08 Apr 2008 21:37 #205138
by vach
1979 kz650 B. Chicago, Illinois
Replied by vach on topic Only runs on starting fluid?
it sounds like you might have a weak ignition.
- Handegard
08 Apr 2008 23:41 #205147
by Handegard
1982 GPz550 H1
Replied by Handegard on topic Only runs on starting fluid?
Hmm. I do have a bad battery, and so I'm jump starting it...
Plugs are new, wires are in pretty good shape.
Problem is I'm forbidden from spending any more money on the bike unless either it's already running (once it's running I'm buying a battery, some tires, etc) or if I can say "Yes sweetie, buying this will 100% garunteed fix my bike"
1982 GPz550 H1
- BSKZ650
- Thank you received: 14
09 Apr 2008 04:51 #205154
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Only runs on starting fluid?
are the plugs getting wet with fuel?
- wiredgeorge
09 Apr 2008 05:46 #205160
by wiredgeorge
Replied by wiredgeorge on topic Only runs on starting fluid?
The pilot system is clogged... could be an internal passageway or the pilot jets.
- vach
09 Apr 2008 10:20 #205208
by vach
well, if you know the battery is bad i would replace it. or give it a very good charge and see if that helps at all. if that doesn't work, sounds like WG is right.
- jrjstuff
09 Apr 2008 10:27 #205210
by jrjstuff
Jeff
83 KZ750 ltd
Replied by jrjstuff on topic Only runs on starting fluid?
With the carbs off I would try some compresed air through the fuel inlet and see of you have a clear passage, if so, it must be the jets or float levels.
Jeff
83 KZ750 ltd
- Handegard
09 Apr 2008 14:49 #205253
by Handegard
1982 GPz550 H1
Well I'm home on my lunch break, so I'll be tearing the carbs off and taking them down to work. Assuming it's a slow day in the 'el shopo, I'll hopefully tear them apart, and check every single jet for restrictions. I'll also throw some air through the fuel rail first to see if it's restricted, and I'll put air through every passage I can.
I'm going to bring the whole bike to the shop sometime in the next few days, and I'll compression test it again, get it on a battery booster to start it instead of cables, and try to buy a new battery.
I'm thinking I'll take all the plastic off, and throw the whole shebang in the solvent tank at work.
1982 GPz550 H1
- Qdude
- It is all good.
09 Apr 2008 17:01 #205283
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic Only runs on starting fluid?
I agree that it would be a good idea to check the plugs as well.
If they look dry and healthy then it must be the carbs.
If they are all wet, then it might be the ignition.
It might be fouled plugs too.
How is the compression?
77 KZ 650 C1.
77 KZ 650 C1.
