1981 GPZ1100 fuelie
- Frank
1981 GPZ1100 fuelie
07 Apr 2008 14:34
Found a fuelie for sale but the poster says it fould plugs often and he seems to thinks its because of it burning oil. The only other thing i know is the bike has a kerker 4-1. For those who know the furl injection system does this sound more like a problem with it?
- howard95132
Re: 1981 GPZ1100 fuelie
11 Apr 2008 15:21
Some of those bikes (mine is an '82) were honed incorrectly at the factory. Mine burned oil (1 qt./500 miles). I've since put an MTC 74mm big bore kit in and I haven't burned any oil since. But even when it did burn oil, I never fouled a plug.
- Mcdroid
- Gone Kwackers
12 Apr 2008 03:33
Could be either issue (FI or rings/pistons). The FI is fairly forgiving and, to some extent, self-regulating. By that I mean, the computer will monitor and regulate air/fuel parameters if one swapped pipes...the owner need not do any adjustments. But, because the owner says it burns oil, I'm leaning towards issues related to rings, cylinders, head/valve seals. Similar to 'howard95132' I also had a 1982 Gpz1100 and it drank mucho oil (but didn't foul plugs). You may not know the answer to this question until you buy the bike and pull the top of the motor...this strongly suggests you should consider these factors when negotiating on a final price for the bike.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
