- Thank you received: 6
rpm's slow to drop
- fordtruck
06 Apr 2008 16:43 #204653
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
rpm's slow to drop was created by fordtruck
I just got done rebuilding the carbs on my 77 KZ1000. The problem I have is the rpm's are slow to drop. If I blip the throttle, the rpm's don't drop as fast as I think they should. It is not the throttle cables because I can see the carb linkage close all the way and the rpm's are still slow to drop. I used 107.5 main jets and 17.5 pilots. Idle mixture screws are set at 1 1/4 turn out. I have synced the carbs. The bike runs great otherwise.
I tried tuning the idle mixture screws, but I could never hear a difference in idle rpm, so I left them at 1 1/4 turns out.
Any ideas??
Thanks
Any ideas??
Thanks
- mcbartell
07 Apr 2008 07:51 #204756
by mcbartell
1976 KZ900
1981 KZ810 Four (sold)
1972 H1 Triple (sold)
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
1997 Tahoe (Toy Hauler) sold
2000 Bonneville SSEI
Replied by mcbartell on topic rpm's slow to drop
You could have a problem with your vacume lines. Mine were capped off when i got my bike, but the plugs were cracked. after replacing them the rpm's dropped like they should.
1976 KZ900
1984 XS850 Special
1982 XS400 (Sold)
1984 HD Low Rider
