- Thank you received: 88
Drilling main jets
- GregZ
- sean5775
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
- bountyhunter
- Thank you received: 337
If I was to size my own jets ,what size drill bit would I need for a 117.5 jet?
I seem to recall the jet number relates to the area of the hole. You have to calculate the diameter and then look up the numbered drill set (standard size). I don't recall the exact formula, I think there are sizes for both English and metric.
I actually went through this a while back, and here is what I remember:
There are more jet sizes than there are standard drills to make the holes to create all those sizes. Ergo, jet makers have a bigger drill set than anybody else and you won't be able to get all the sizes like they do using a standard drill set.
- bountyhunter
The really small drills come in the numbered series, not actual diameter sizes.The smallest drill bit I have is 1/32 of an inch and it does not fit in a 117.5 Jet. Good luck finding a smaller drill bit. Z1 enterprises sells these jets for $2.00 each.
I agree jets are so cheap you just buy a bunch and go for it. save the extras, you'll have them if you buy new headers or air pods.:laugh:
- sean5775
I actually went and tried and I do have lettered and numbered drill bits, about every size available and the smallest bit I had was 1/32 of an inch and that was slightly too big to fit through a 117.5 Jet.
- steell
MSC has them down to at least .0059" (Wire size 97), is that small enough?
Whoops! Found one even smaller, .0051".
Search for "Micro drill bits" at MSC.
Kept looking at MSC just to see how small they go, found one .0019", if you need one smaller than that you're on your own
- wiredgeorge
