- Thank you received: 19
3 out of 4 sooty plugs
- KZ_Rage
- Kentucky Bourbon Barrel Ale
If you have a 1000 with good spark, clean and rebuilt VM28 pumper carbs that are all setup exactly the same with working pumps, your valves are in spec and plugs 1,2 & 4 are sooty but #3 is just perfect... what would you think is causing this to happen, where would you look first???
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- bountyhunter
- Thank you received: 337
Do you have good, smooth power from low speed to full throttle? Good throttle response?
On mine, the pilots run the show from idle up to maybe 2500. Needle position strongly affects throttle response in the 2000 - 3500 range. mains run the engine from about 4k up at large throttle openings.
Just for info, I might try this:
1) Clean the plugs
2) take your spark plug wrench and do about 10 miles down the freeway as fast as possible and check the plug color. Is it sooty, white, tan?
3) Clean the plugs and try low speed city driving and keep the revs down and the throttle closed as much as possible. Check plug color.
Do you get sooty plugs both times? The pilots will be doing most of the work in low speed, more the mains and needles on the freeway.
The "one carb good" is really puzzling. I wonder if it's possible the jets are set up rich and one carb has a vacuum leak leaning it out a little?
The only other guess might be the fuel level in the bowl is low and that would make it run a little leaner?
- KZ_Rage
First thing I would do is make sure the fuel levels in the bowls are set right (adjust the float tangs).
I have as best you can with the clear tube method.
I did with the 20 pilots but things are not going well with the 17.5's. Both sets though resulted in sooty plugs.Do you have good, smooth power from low speed to full throttle? Good throttle response?
Should be the same for just about all VM's I'd guess.On mine, the pilots run the show from idle up to maybe 2500. Needle position strongly affects throttle response in the 2000 - 3500 range. mains run the engine from about 4k up at large throttle openings.
I guess that is possible. I do find it odd that hte reference carb is the one carb that is running right.The "one carb good" is really puzzling. I wonder if it's possible the jets are set up rich and one carb has a vacuum leak leaning it out a little?
They are all supposed to be the same height but I guess it could be splitting hairs as to whether they are all the exact same height or just a tiny bit higher than this one. I would have though it would take more than what I saw as differences based on the FSM height range shown.The only other guess might be the fuel level in the bowl is low and that would make it run a little leaner?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- KZ_Rage
Here is the link to the electrical post and it will give you more info on the rest of the engine as well:
kzrider.com/index.php?option=com_kunena&...d=4&id=203799#203799
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- bountyhunter
I can say this: when I was dialing in mine to the new headers, I was sooting plugs because my pilots were too rich. I was trying to get better low speed throttle, but it turns out that riching it up at the needles was the best thing and then I went to leaner pilots and now it runs perfect and the plugs are clean.
Don't know if your pilots are too rich. Do the low speed run and see if the plugs blacken up on you. If they soot up at low speed and run right at high speed, the pilots probably are too rich.
The tuning procedure I have seen is always to get the right main jet first (by running high RPM, wide throttle opening).
Then do the needles, pilot jets last.
YMMV
- KZ_Rage
I'll pull them back off again and crack the rack this time.
I'll drop in 15 pilots and drop the 117.5's mains down to 115's plus lower the floats a little again. I will go over every orifice, o-ring and gasket.
When done if it does this crap again, these 28's are going to the shelf and I'll throw on a set of 26's I have until I can find some newer flatslides.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
