Fuel filter question
- 390fe
29 Jan 2006 07:59
For those of you that have added aftermarket fuel filters to your bikes, what brands/models did you use and does it perform well?
- oldcoldankles
Re: Fuel filter question
29 Jan 2006 08:39
I've had really good success with a fuel filter that NAPA carries - no flow problems at all. It is similar in appearance to the one in wiredgeorge's recent Fram fuel filter post, but probably a different manufacturer, like WIX. These ones flow fuel just fine, and you can verify that the flow is adequate by turning the petcock briefly to PRIME with the hose to the carbs disconnected.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
1981 KZ1000 CSR M1
1989 Corvette coupe
- savedrider
- 1975 Z1-B 900
30 Jan 2006 16:19
Ditto on the Napa Gold filters!
Get right or get left! <*{{{><
30 Jan 2006 20:56
I use a Russell 1/4" filter. The bronze element is replaceable or it can be cleaned. Russell makes professional grade fuel components for racing. See:
www.denniskirk.com/jsp/search/search.jsp...tring=russell&page=1
