Looking for Carb mount help
- rdgrnr
01 Apr 2008 18:59 - 01 Apr 2008 19:01 #203616
by rdgrnr
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
Looking for Carb mount help was created by rdgrnr
Anyone know the trick for putting the carbs back on to the stock airbox?
Spent 1/2 hour earlier trying, but can't get them to sqeeze in past the top of the rubbers on the engine side (PITA) :S
The airbox boots are new.
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Last edit: 01 Apr 2008 19:01 by rdgrnr.
- Sandy
- Fly High,Tony
- Thank you received: 13
01 Apr 2008 19:48 #203631
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic Looking for Carb mount help
A few small(er) flat screwdrivers...some WD40...and a heatgun to soften the rubber.(don't ignite the WD40,or melt the rubber boots though,lol).
A couple of very small pry-bars,or something with a soft,gentle hook will help also.Don't use anything sharp.
Honestly though...it's been a lot of years since I had to deal with an airbox,but I DO remember those items making it easier.
Having another set of hands will for sure make it easier too.One person on each side of the bike.
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
01 Apr 2008 19:50 #203632
by Sandy
1977 KZ1000 A-1
Start with mounting them to the engine first.(almost forgot)
The rubber is thinner on the airbox,and easier to manipulate.
1977 KZ1000 A-1
- Bluemeanie
- Thank you received: 14
01 Apr 2008 20:38 #203637
by Bluemeanie
Replied by Bluemeanie on topic Looking for Carb mount help
I mount the carbs to the carb holders first, clamp in place. Then I feed each boot from inside the airbox (mine are new so I can fold them easily) onto each carb. I also do this out in the driveway in the warm sun which makes things easier too. Even with new warm boots it's still a PITA!
- rdgrnr
03 Apr 2008 15:19 #204045
by rdgrnr
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Replied by rdgrnr on topic Looking for Carb mount help
Sandy, I tried your suggestion one more time and gave up.
I wanted to throw the carbs down the freakin' driveway:laugh:
So, this morning after setting up a halogen worklight next to the bike for warmth (was still 39 degrees F) and tried Bluemeanie's idea and it worked perfectly. Was still a PITA, but much less cussing:laugh:
The boots are brand new, which I'm sure made it much easier.
Thanks guys
I have a thread on my progress in projects.
Thanks guys
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- 77_650B1
03 Apr 2008 15:21 #204047
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic Looking for Carb mount help
yeah biggest PITA ever
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Thank you received: 2829
03 Apr 2008 16:11 #204050
by 650ed
Replied by 650ed on topic Looking for Carb mount help
After you've done them a few times it gets much easier (because you remember to have a good belt of Scotch before you start). Ed
- rdgrnr
03 Apr 2008 16:51 #204058
by rdgrnr
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
...or Windsor
4 or 5 of those, then who cares, it'll wait til tomorrow:P
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- Sandy
- Fly High,Tony
03 Apr 2008 17:14 #204069
by Sandy
1977 KZ1000 A-1
ha ha...glad you got it figured out bud.
( I sure love my K+N's )
1977 KZ1000 A-1
- reborn650
03 Apr 2008 19:21 #204106
by reborn650
-1998 Jeep TJ Wrangler 4.0...
Replied by reborn650 on topic Looking for Carb mount help
I prefer using a hair dryer to heat up rubber to make it more malleable. If have found that a heat gun it too hot and can easily burn rubber if left in one spot too long. Additionally, the blower moves the hot air all around instead of focussing the heat in one area.
Just my 2 cents worth discovered through trial and error:)
