- Thank you received: 12
1980 kz 650e carb problems
- oldkaws4ever
- Have no regrets...... You only live once.
30 Mar 2008 22:55 - 30 Mar 2008 22:57 #203205
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
1980 kz 650e carb problems was created by oldkaws4ever
My girlfriends brother just got a 1980 kz 650e, with 10,000 miles on the clock a v&h 4into1 and pods. The bike has sat for the last 3 years with gas in the tank and carbs. I went over there today to help him get it started, only to find that the carbs were competley stuck closed, but i got the slides to free up. I got it to start but it instantly revved up to 5 or 6000 rpm's and it would not idle back down. My question is can i switch the petcock and carbs from my 1977 kz 650b to the 1980 kz650e. i have the same set up as him 4into1 v&h header and pods the carbs on my bike have been jetted for the pipes and pods. If anyone has any advice let me know. Thanks
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 30 Mar 2008 22:57 by oldkaws4ever.
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
31 Mar 2008 04:14 #203213
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic 1980 kz 650e carb problems
I can't think of any reason why not, I swap carb banks between bikes all the time. The only thing I can think of that you will have to do in this case is to block off the vacuum hose that leads to the petcock assuming your 650B petcock is the original manual type. Just use a small screw to plug the hose and you should be fine.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- bemoore
- Thank you received: 4
31 Mar 2008 05:16 #203223
by bemoore
77 KZ650C1 w/Kerker 4-1
Replied by bemoore on topic 1980 kz 650e carb problems
The sync may be a little off. But if both bikes have decent compression, your carbs should work fine.
- oldkaws4ever
31 Mar 2008 12:17 #203306
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic 1980 kz 650e carb problems
Thank you for the quick reply's, im going over by his house tommorow and ill report back when i get home.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
03 Apr 2008 20:20 #204120
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
sorry for the wait, i have had to work alot lately. I went over there tuesday and put my carbs on. It fired right up and with a little tinkering she was purring like a kitty cat. That thing rode like a raped ape, and sounded awsome to boot.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
