Where do these hoses go
  • Scotty355
  • Scotty355's Avatar Topic Author
28 Jan 2006 20:04
#20315
Are the clear plastic hoses in the pic vacuum hoses or just breathers? I checked my chiltons and it doesn't show any hose routing off the carbs. The bike is a 79 650 csr
  • Tower_Monkey1
  • Tower_Monkey1's Avatar
Re: Where do these hoses go
29 Jan 2006 00:12
#20345
breather tubes, just run them down toward the swingarm...
78 KZ650C2 Dyna ignition and coils,Pod filters,4-1 Kerker,CBR Tail Light,Drilled front dics,Custom front fender,1/4 fairing.
  • Scotty355
29 Jan 2006 04:49
#20354
Thx
  • wiredgeorge
  • wiredgeorge's Avatar
30 Jan 2006 07:42
#20519
Scotty, They are indeed float bowl vent tubes and must not be capped or pinched or the floats won't work. I would also point out that the black rubber hose immediately behind the clear hose on #2 carb is a vacuum hose intended for connection to your petcock. It actuates the petcock. If not used, it MUST be capped or makes a big air leak in that carb.
  • Scotty355
30 Jan 2006 16:35
#20607
Wanna hear a good one? I just bought the bike and it didn't run too good, I thought they were just breathers but i wanted to ask anyway, the previous owner had 1 of the breathers on the petcock and the vacuum hose plugged.
Thx for the info
30 Jan 2006 21:01
#20664
On my '77 KZ650C1 those 2 breather hoses are routed up, then under the air filter baffle plate, then down into the center of the top of the air filter. I'm the original owner of the bike, and this is how it came from the factory. Ed
  • Scotty355
31 Jan 2006 16:29
#20781
Thanks, The previous owner took out the air box for some reason and I am looking for one now on e-bay unless someone out there has a spare?
