Ball-bearing
- osirus_4
Ball-bearing
28 Mar 2008 13:04 - 28 Mar 2008 13:04
I recently bought a 1981 kz750h. It was starting but having problems idling. After changing the plugs and air filter I was having no better results with the idle so i decided to remove the carbs and give them a cleaning. I now have two problems; the first is when I was taking the vacuum line that goes to the airbox off I noticed that there was something stuck in the hose. I worked the obstruction out and discovered that there was a small ball-bearing stuck in it. Any ideas why someone would do this? The second problem is I can't get the carbs back on the bike. Any tips on putting them back on would be appreciated.
Last edit: 28 Mar 2008 13:04 by osirus_4.
- TheTrout
Re: Ball-bearing
28 Mar 2008 17:01
I find a little wd40 on the rubber boots makes them slide on much easier.
1978 KZ1000B2
Re: Ball-bearing
28 Mar 2008 17:53 - 28 Mar 2008 17:55
osirus_4 wrote:
WD40 is okay, or Armoral, silicon spray, or similar product.
On the large fours, once the throttle cables are attached and the carbs started into the carb holders, I use a wooden vampire stake, broom handle or similar "tool" to lever the carbs on into the holders. :lol: And the carbs readily slide snugly right into place without drama.
Good Luck!
...recently bought a 1981 kz750h...can't get the carbs back on the bike. Any tips on putting them back on would be appreciated.
Good Luck!
Last edit: 28 Mar 2008 17:55 by Patton.
- osirus_4
Re: Ball-bearing
29 Mar 2008 08:48
Thanks for the tips. No one knows anything about the ball bearing. I have talked to mechanics and no one seems to know any positive reasons as to why a ball-bearing would be obstructing a vacuum line. I guess I will see if it makes a difference when I get the carbs back on the bike.
- KZQ
- Administrator
Re: Ball-bearing
29 Mar 2008 14:38
A ball bearing or marble is used to quickly and elegantly plug a vacuum line that you no longer want to work. It also allows you to plug the port it's connected to without a plug or cap.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
