air/fuel adjustent
- kzwolfsr
air/fuel adjustent
27 Mar 2008 06:28
Which way to turn the air/ fuel screws to add more gas? on a 78 650, mikuni! Thanks
Original man of the Caribbean
- RonKZ650
Re: air/fuel adjustent
27 Mar 2008 06:39
You have the airscrew type carbs, so opening the screw adds more air, closing it decreases air, so in other words to richen the mixture turn the screw clockwise.
- kzwolfsr
27 Mar 2008 11:34
Thanks Ron!
- Qdude
- It is all good.
27 Mar 2008 13:10
Counterintuitive huh?
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- kzwolfsr
28 Mar 2008 10:49
Huh?
- Qdude
- It is all good.
28 Mar 2008 10:59
I am used to fuel screws. Turn them in to lean the mix. With the air screws you turn them in to enrichen the mix.
To me, this feels counterintuitive.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
28 Mar 2008 12:31
Qdude wrote:
The tapered point covers an air hole.
- bemoore
28 Mar 2008 18:17
Qdude wrote:
Depends on what you're used to. I've owned my KZ for over 20 years. So I'm used to it as it is.Counterintuitive huh?
77 KZ650C1 w/Kerker 4-1
- Qdude
- It is all good.
28 Mar 2008 23:58
I did/do the R/C airplane thing. Those little motors need high and low rpm mixture tuning.
Adjusting one tweaks the other. Plus, you need to tune those little motors pretty much every time you go out with them, and they are really finicky.
Old habits I guess...
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
