kz750 n2 spectre vacume problems
- michaelbibb
26 Mar 2008 20:11
i need to put a vacume line on the fuel tap but i dont know which carb or carbs to put it on. any help would be greatly appreciated
- Qdude
- It is all good.
Re: kz750 n2 spectre vacume problems
26 Mar 2008 23:58
My four cylinder Mikunis have a capped hose fitting on each of the carbs. They are meant for hooking up a manometer to fine tune the carbs. I just used one of those.
I don't know which carbs you have though....
Perhaps they don't have the same hardware.
If you see any capped hose fittings, pull one to see if you create a vacume leak. then use that.
Or pull and replace hoses 'til you find one tha creates a vacume leak, the get a T-fitting and splice your hose into that one.
Just a couple of ideas.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
- JR
27 Mar 2008 05:53
If the carbs are Keihins then attach the vacuum line to the nipple on carb #2.
- coppertales
28 Mar 2008 10:28
I have always picked up a T fitting at an auto parts store and tapped #2 and #4 carbs for vaccuum to the fuel petcock.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- michaelbibb
28 Mar 2008 19:59
thanks for all the input. i am going to be workin on the bike tomorrow. i will let you know how it works out.
- michaelbibb
30 Mar 2008 08:58
well, i got everything done to my bike that i wanted to do. I installed the vacume line for the petcock, fired it up and runs great. i thank all of u for the help, i really appreciate it
mike
mike
