One cylinder running rich
  • wiredgeorge
  • wiredgeorge's Avatar
Re: One cylinder running rich
27 Mar 2008 16:21
#202561
Nate, Please amplify your comments, they make no sense to me. What is a "main jet needle"... are you talking about the float needle? As it fits up in the seat, it protrudes out of the seat perhaps .25mm? Not much, but they add a spring loaded pin for contacting the float. Unless an incorrect needle were used, how could it be a different height? Not trying to be a wise-guy... would just like to clear this up. Perhaps you are thinking in an entirely different direction I am not seeing. God bless and thanks! wg
28 Mar 2008 09:36
#202677
N0NB wrote:
There is always the chance that the main jet needle is a different height than the others.
28 Mar 2008 09:47
#202680
Patton wrote:
kzrider.com/media/kunena/attachments/leg...mages/jet_needle.jpg [/img]
Here's a better pic of jet needle (I hope)
  • bountyhunter
  • bountyhunter's Avatar
28 Mar 2008 09:49
#202681
Patton wrote:
The Keystar rebuild kit I got for my BS38s had needles which were about 1/8" shorter than stock.
28 Mar 2008 09:59
#202682
And here's a typical float needle, sometimes referred to as a float jet needle
  • Qdude
  • Qdude's Avatar
  • It is all good.
28 Mar 2008 10:38
#202695
I took it to mean that the carb has it's main jet (not float needle) set richer than the rest of the carbs.
77 KZ 650 C1.
77 KZ 650 C1.
  • fordtruck
  • fordtruck's Avatar Topic Author
29 Mar 2008 13:08
#202919
I used the clear tube method to check the fuel level in #4. It was level with the bottom of the carb body. I adjusted it so it was 1/8" below the body and the bike ran like crap. It was backfiring and terrible throttle response. It also had a wandering idle. One minute it would idle too slow and almost die, then if I blipped the throttle it would idle about 1500rpm for a while, then slowed down. I pulled the carbs off and the o-rings on the idle mixture screw and the tube the main jet screws into are shot.
I ordered a rebuild kit for all four carbs. I noticed I have 107.5 mains and 15 pilots. My Clymer manual lists 107.5 mains, but 17.5 pilots for a 77KZ1000 standard. Should I put 15 or 17.5 pilots in it?
Oh, and I did check the needle in #4. It has the correct needle and the clip is in the middle position, which my manual lists as the stock setting.
'77 KZ1000-MTC 1075 kit. Stage 1 port
  • sean5775
  • sean5775's Avatar
29 Mar 2008 19:55
#203008
If you have K&N Pod Filters, which you did not specify, and the aftermarket exhaust system which you said you have, than normally you have to jet your carbs a little richer than stock. I had these same issues with other bikes I have owned. But still does not explain why one cylinder is rich and the others are fine.
1972 Kawasaki H2-750 Triple Mach IV
1976 Kawasaki KZ900 A4
1981 Kawasaki KZ440 LTD
1981 Kawasaki KZ750LTD-4
1983 Suzuki GS650 Tempter
1981 Yamaha Virago XV920
  • fordtruck
30 Mar 2008 12:00
#203105
The bike has a K&N filter in the stock airbox. It has a Vance and Hines 4-into-1 pipe with baffle.
Hopefully between a good cleaning and the rebuild kit, this will fix my problem.
  • fordtruck
30 Mar 2008 18:22
#203161
I just got done disassembling the rest of the carbs. Three of the four idle mixture screws have been blunted from overtightening. They are over 1/8" shorter than the one good screw. The carbs were pretty dirty too. I'm shocked the bike ran as good as it did. Now I just need my rebuild kits.
