Worn throttle slide
- BA KZ550
24 Mar 2008 20:25 #202017
by BA KZ550
Jason
Broken Arrow, OK
1981 KZ550 LTD
Worn throttle slide was created by BA KZ550
I've been having all sorts of issues with my bike. Mostly hard start and erratic idle. So I rebuilt the carbs and changed the plugs to no avail. While I had the carbs apart I noticed several worn spots on a couple of the slides what kind of issues can this cause if any at all?
Jason
Broken Arrow, OK
1981 KZ550 LTD
- The Milkman
- Thank you received: 194
24 Mar 2008 23:21 #202038
by The Milkman
Replied by The Milkman on topic Worn throttle slide
If they are Mikunis and it is just slight scuffing it shouldn't be a problem at all. If it is really nasty and worn so the slide moved around it the bore it could eventually cause excessive wear in the needle and jet but that would be unlikely. The only other problem that I can think of,, still figuring them as Mikunis would be if the cover gasket on the carb or the shaft seals that seal the pivot shaft are too loose, that could cause an air leak around the slide making the mixture lean. But in my mind that is also unlikely, but possible.
Just my thoughts on the matter.
- BA KZ550
25 Mar 2008 10:05 #202098
by BA KZ550
Jason
Broken Arrow, OK
1981 KZ550 LTD
Replied by BA KZ550 on topic Worn throttle slide
I don't remember what carbs they are I will check when I get home. I forgot to mention that the bike is an 81 KZ550 LTD. If that helps.
Jason
Broken Arrow, OK
1981 KZ550 LTD
- The Milkman
26 Mar 2008 12:01 #202298
by The Milkman
Buykawasaki.com shows them as Mikunis.
- Qdude
- It is all good.
26 Mar 2008 12:13 #202301
by Qdude
77 KZ 650 C1.
77 KZ 650 C1.
Replied by Qdude on topic Worn throttle slide
I think the worst about the scuffing is that you will know it is there and it will bother you, but no one else will ever be able to tell. Barring them yanking your carbs apart.
77 KZ 650 C1.
77 KZ 650 C1.
- mariozappa
- Thank you received: 8
26 Mar 2008 12:15 #202302
by mariozappa
1977 KZ650C1
and the KZ650/KZ750 Conversion
Replied by mariozappa on topic Worn throttle slide
I didn't see anywhere on the website that it called them Munkuni's. But they sure do look like TK's to me. ???
1977 KZ650C1
