KZ1000 high and low idle problem
- parker
24 Mar 2008 11:40 #201947
by parker
KZ1000 high and low idle problem was created by parker
I have a 79 KZ 1000 I bought last fall. Riding it in the rain made it die. I found cracks on the ignition coils, and replaced them. It ran fine for a while, but then started to idle really high when choked at start up. When I lower the choke to off, it dies even after almost 10 minutes of warmup. I have to keep the choke on just to keep it running, but not too high or it will idle extremely high. Any help would be great. Thanks.
- wiredgeorge
25 Mar 2008 06:21 #202060
by wiredgeorge
Replied by wiredgeorge on topic KZ1000 high and low idle problem
Sounds like you have a major air leak. Your petcock is connected to the carbs via a hose. There are vacuum caps on the carb holders. The emissions equipment may be compromised (hoses cracked/missing? I would carefully check every point air can leak in; especially those that have hoses or caps.
