Petcock rebuild
- rdgrnr
22 Mar 2008 10:04 #201560
by rdgrnr
77 KZ650B1
80 440 LTD Sold
78 GL1000 Naked Wing Sold
80 CM400E Sold
Brainerd, MN
Petcock rebuild was created by rdgrnr
Hey all,
I've checked a few threads on people trying to find rebuild kits for the 77 650, with no luck.
Has anyone found anything that worked, other than buying the aftermarket replacements. Is there other makes that will work for the spacing?:S
Thanks
Thanks
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
- RonKZ650
- Thank you received: 240
22 Mar 2008 10:14 #201561
by RonKZ650
Replied by RonKZ650 on topic Petcock rebuild
If it's an original 1977 with the manual petcock, there is really nothing to rebuild except replacing the lever oring 670B2010 and bowl oring 51037-010. Buy those 2 orings for $5 or so and you're all rebuilt. Lube the lever so it turns easier is all that's involved otherwise. You can also update to newer vacuum petcocks and run the vacuum line to any of the 4 carb sync ports on the intake rubbers. Any newer KZ650, GPZ, KZ750, KZ1000 vacuum petcock with the same dual bolt mounting should bolt right up. Otherwise use the Suzuki petcock as others have done. Too lazy to search now, but you should find the threads here.
- rdgrnr
22 Mar 2008 10:22 - 22 Mar 2008 10:31 #201562
by rdgrnr
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Replied by rdgrnr on topic Petcock rebuild
Thanks Ron,
Where do I find the o-rings?
77 KZ650B1
80 440 LTD Sold
80 CM400E Sold
Brainerd, MN
Last edit: 22 Mar 2008 10:31 by rdgrnr.
- RonKZ650
22 Mar 2008 10:50 #201567
by RonKZ650
I think they are both pretty common. Any dealer can get them or bikebandit.com. Hopefully they are still available, they should be.
- anarki650
- Thank you received: 5
22 Mar 2008 16:53 #201618
by anarki650
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Replied by anarki650 on topic Petcock rebuild
The petcock from any of the B or C models will fit, but I'm not sure beyond that (never seen a D, which is the SR, petcock) but I know that the 81 650h1 (CSR) has different spacing for the bolts than the B (I have both a 77 b1 and an 81 h1 that I've compared trying to swap parts).
09 Kawasaki ER6n
Omaha NE
- davenkids2001
24 Mar 2008 06:06 #201880
by davenkids2001
Dave and Janet
Great Lake State
1979 650SR
Replied by davenkids2001 on topic Petcock rebuild
My opinion only of course but...
I grew weary of trying to rebuild my previous vacuum-assisted petcock. I never could get it to work correctly after 2 rebuilds.
In the end I contacted Z-1 enterprises (the link is in the vendor section). I purchased a NEW Suzuki petcock, also a vacuum assisted model. I don't remember the cost but it was little more than buying the rebuild kit and it was NEW!
Nary a problem since.
-Dave
-Dave
Dave and Janet
Great Lake State
1979 650SR
- Wild and KZ Guy
22 Dec 2008 12:12 #254137
by Wild and KZ Guy
A couple of Old School Minibikes
1980 LTD KZ650 E1
Replied by Wild and KZ Guy on topic Petcock rebuild
Hey Dave, do you happen to know the part# of that petcock you got from Z1? THanks!
1980 LTD KZ650 E1
- Bluemeanie
- Thank you received: 14
23 Dec 2008 05:57 #254257
by Bluemeanie
Replied by Bluemeanie on topic Petcock rebuild
Here ya go KZ Guy,
Z1 Petcocks
- JMKZHI
- Thank you received: 48
23 Dec 2008 06:07 - 31 Dec 2008 15:54 #254258
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 31 Dec 2008 15:54 by JMKZHI.
- bill_wilcox100
23 Dec 2008 07:24 - 23 Dec 2008 07:31 #254269
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Petcock rebuild
rdgrnr, try this post:
LINK
IMHO, I don't like the hoses coming out the right side. With my Pingel the fuel-out hose hits my frame and is hard to remove tank.
Best of success.
LINK
Best of success.
Upgrades:
Montreal, Canada
Last edit: 23 Dec 2008 07:31 by bill_wilcox100.
- Wild and KZ Guy
23 Dec 2008 11:15 #254291
by Wild and KZ Guy
1980 LTD KZ650 E1
Excellent! Thanks again, and Merry Christmas to all:cheer:
1980 LTD KZ650 E1
- MFolks
- Thank you received: 540
23 Dec 2008 11:30 #254296
by MFolks
Replied by MFolks on topic Petcock rebuild
Another website to look at is
www.reproductiondecals.com
They carry a lot of NOS parts for the older Kawasaki triples and 4's.
