1980 LTD 550 fuel line routing
- ada2831
- born in england.now live usa
16 Mar 2008 06:36 - 16 Mar 2008 06:54 #200286
by ada2831
1980 LTD 550 fuel line routing was created by ada2831
just brought a non runner,have cleaned the carbs but there was only one fuel line attached to main rail.have noticed that there are 2 outlets on fuel tank and additional connections to the carbs!i know a manual will help and that is my plan(when money is available).thanks.
Last edit: 16 Mar 2008 06:54 by ada2831.
- Bluemeanie
- Thank you received: 14
16 Mar 2008 06:46 #200289
by Bluemeanie
Replied by Bluemeanie on topic kz 550 fuel line routing
We don't know what year, model bike your working on, put this info in your signature line so we can help you better...
- Locozuna
16 Mar 2008 07:33 #200297
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic kz 550 fuel line routing
I kinda think the title has clues...
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- JMKZHI
- Thank you received: 48
16 Mar 2008 07:38 - 04 Dec 2008 05:49 #200298
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 05:49 by JMKZHI.
- ada2831
16 Mar 2008 08:28 #200317
by ada2831
Replied by ada2831 on topic kz 550 fuel line routing
thanyou for the info.kawasaki.com was a great resorse.
- Bluemeanie
16 Mar 2008 08:31 #200318
by Bluemeanie
Duh!! Yea, I missed that part Locozuna! :huh:
- Bluemeanie
16 Mar 2008 08:40 #200322
by Bluemeanie
This might also help (click on pic for full size)
1) Large brown hose (center) is main fuel from petcock
2) Two thin lines in top (left and right) are vent hoses which drop down behind side covers.
3) Smaller line to left of main fuel line is vacuum source for fuel petcock.
4) Four thin lines on bottom of carbs are float bowl overflow lines.
5) Nipple on each carb holder are normally capped unless smog device still in service in which two nipples are normally used.
- mjg15
16 Mar 2008 11:57 #200363
by mjg15
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
Replied by mjg15 on topic 1980 LTD 550 fuel line routing
Check out GPz550 forums .
www.nwsca.com/scripts/gpz_forum_2005/forum.asp?FORUM_ID=2
Much is shared with the two bikes . Your carbs are the same as the '81 GPz550 . Search the tech form for a lot of info . I also think that there is a manual that can be downloaded for thr GPz site .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- ada2831
16 Mar 2008 15:17 #200422
by ada2831
thankyou,this is very helpful.
