- Thank you received: 1
Rejetting issues with KZ750B3
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- wiredgeorge
- wiredgeorge
- bountyhunter
- Thank you received: 337
I have a completely stock KZ750B3 (twin) and I am putting a Macs 2-1 exhaust on and replacing the air filters with K&N slip-ons (Ithink that is what those individual filters are called??) So I was wondering If I could use the stock jetting or If I need to rejet? Could I just set the needle that is in the CV up higher possibly?? I ride at around 1000 feet above sea level and it rarely changes much. Also How do i go about rejetting?? I've never done it before and any tips would be much appreciated.
If you keep the stock airbox I can tell you EXACTLY how to jet those headers.... I put a set of Mac 2-1 on my KZ750B4. Mine has the Mikuni BS38 carbs. If yours does also, then here is the right setup:
Main jet: stock 125
Pilot Jets: go UP to #50
Needles: go to maximum rich setting (move clip to bottom slot)
I screwed with mine for a long time to get them peaked up.
If you put on air pods I have no idea how to make it run right. It probably never will run exactly right again, but they will certainly make it run leaner.
- bountyhunter
True. Those jets are not available ANYWHERE. I found the "Keystar" or "Keyster" brand rebuild kits came with the correct stock main jets. I bought a set of those kits just to get the jets.Does the B3 have the small main jet carried in the float bowl? If so, I would reconsider my plan to stick those pod air filters on the bike since the little main jets are not available in larger sizes that I know of.
- Shoe48
- Live each day as it is your last
- Thank you received: 5
- bountyhunter
You can get the Jets from England , I have a friend that lives there and sent them to me ,, You might look online to see if you can find them in the UK ,, ,, with pods it is a 150 main and I think the 50 pilot ,, You might try the drill out method ,, just go slow .
I know some fool who drilled his main jet too far.... so, he buffed up the brass real bright and torched the jet hole full of silver solder and drilled it again with a smaller drill.
- Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- wiredgeorge
- bountyhunter
Really good advice. BTW, when I did the calculations, the size steps in standard numbered drill sizes miss quite a few of the available jet sizes. The guys who make jets must have a really good set of drills.I personally wouldn't drill ANY jet much less those bitty little mains.
- bountyhunter
The stock pilots that came on my B4 were 40's and they ran way too lean even with the stock pipes. I used to have to run with the choke on until it was fully warmed up and even then it had some really bad lean spots. I kept taking it back to the dealer and complaining and he said it would be illegal for him to install richer jets because of smog laws.... but apparrently he drilled them because they say "40" on the side and the hole is the size of a "50" and the bike ran a whole lot better. I left those pilots in when I got the kerkers and went up one size on main and it ran great. When I got the MAC's I bought a full set of new pilot jets to make sure I knew the true size and the 50's do run the best on mine with the MAC's. 47.5 is rideable but a shade lean. YMMV.If you call z1enterprises.com they will have them or can get them in #47.5 or try bountyhunter's suggestion of a #50 which sounds a bit rich to me. I doubt a Mac 2 into 1 flows much better than a stock system... I would try using the stock set up before rejetting anyway.
