83 750 twin carb info needed
- Wildh2oskier
Does anyone out there have any idea what the baseline settings for these carbs are? If I can get it run I can take it from there.
Thanks again
WildH2oskier resident super genius
- bountyhunter
- Thank you received: 337
The needles are set in the center notch (#3).
Don't know what else you could have changed.
- steell
You did set the float level when you reassembled them right?
Check the plugs to see if they are wet with gas, if not then determine why.
Check to see if you are getting spark, maybe the problem is not related to the carbs, might just be a coincidence.
- Wildh2oskier
However it wanted to cut out at over 50 mph. So I was thinking that I need to adjust them again in about 1/4 to 1/2 a turn. I would have done it tonight but while I was stopped filling up the tank on it a young guy on a Suzuki 750 croth rocket was filling up next to me. Well we got to talking and comparing the difference in technology then he left. When he took off he was showing out and left like a bat out of hell, I took a different route since I was still confused about this cutting out problem and wanted to put a few more miles on before I went home. After a while I turned and doubled back to go home and make the adjustments. This route took on the way that my newly met fellow rider had taken. You can guess the rest, I topped a hill and saw the ambulance, the crowd and the wadded up bike lying across the road from a very dinged up looking SUV.
I just couldn't bring myself to stop so I don't know how he is, its not that I don't care its just I don't think I'm scared to know.. So I limped on home and parked it in the garage. That brings me to now, I hugged my girls and took some time to think about it. So now on my second Jack and Sprite I felt that maybe putting this story down might help me make a little more sense of it.
Just because the bike was built so that it can be ridden like that, and its a hoot to ride'm like that doesn't mean that you ought to ride it like that.
Ya'll be carefull out there its a dangerous world. Please excuse the grammatical and spelling errors but I really don't feel like editing this right now.
- ronjones
- Thank you received: 4
On the cutting out problem. Are you running the stock airbox? You might want to get some "sea foam" and run it through the gas also some people have a problem w/the gas tank not venting and forming a vacume in the tank cutting off gas flow. Try riding w/the gas cap not sealed and see if it still cuts out.
- wiredgeorge
- Becker
- The Doctor Will Rise Again
- Thank you received: 1
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- bountyhunter
Reminds me of the time I priced a brake rotor for mine and it was like $700.I like the idea of taking off the tops and inspecting the diaphrams. I had a similar problem on my KZ400 which also uses rubber diaphrams and when I went to check the carbs one of the diaphrams was disconnected. I bought a replacement on ebay after checking the costs at the kawasaki dealership ($410 !!!) but I haven't put it on yet to see if that was the only problem.
