working on bike now and need help
- mlh300zx
- KZQ
- Administrator
- Thank you received: 1415
Is there any chance you've inadvertently bent the tang on the float?
KZCSI
Post edited by: KZCSI, at: 2008/03/02 10:42
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- mlh300zx
- mlh300zx
- Thank you received: 2098
Good Luck!
i just went and tested to see if they leaked with the bike off and the gas on pri. and they do. if i read some things correctly i think it means my petcock needs rebuilt. i hope thats it.
When float needle/seat interface is performing correctly, it should not leak regardless of petcock position.
But still a good practice to turn off a manual (non-vacuum) operated petcock while the bike is parked.
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
1. Clean out your tank with a good tank flush product.
2. Install an inline filter.
3. Re-clean your carbs and use air pressure to clean all small passageways.
4. Pay special attention to the float valves.
5. Worry about the petcock only if you can prove it is faulty.
P.S. I finally gave up on the stock petcock and installed a Pingel manaual on-off type. Apart from having to remember to turn the gas on and off, it works great.
Good luck,
Grant.
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- Qdude
- It is all good.
They are rubber cones that set in a round hole. There is probably some crud stuck to the metal hole part that is keeping the valve from closing completely. If of course the adjustment tabs were not bent while you were cleaning.
On mine, I remember pulling the carb and bowl off and blowing air through the carb bowl's fuel feed port while working the float up into the valve. There would be something horrifically wrong if you were able to blow air through. I had a couple of "bad" ones that needed to be pushed harder than the other two to finally seal.
Many people would replace them, just to be sure. Carb rebuild kits were expensive though.
Are they sold separately? Or would you want to replace the gaskets and all as well while you were at it?
77 KZ 650 C1.
77 KZ 650 C1.
- hwms
- wiredgeorge
Another thing to check if gas is pouring out is that if the venting is plugged, the floats DO NOT WORK AT ALL and will either hang and not allow gas through at all or will drop and gas will pour out. Most all the other suggestions are good in this thread and this is just one more thing to check.
- mountain
- go with the flow
- Thank you received: 3
Make sure the float valve needles are functioning, look at them with a magnifying glass, and drop the float levels for all four just a tad by bending the "tang" a wee bit.
1977 KZ 650 B1, I own two of them. Working on one custom rebuild, one daily rider. Used to have a third. Two 1978 KZ 650 C2 models, sold both. KZ owner since 1987.
...Fuel was making it into the intake manifolds and filling up on top of the cylinder and fouling a plug before it would get as high as the overflow tube inside the carb. I guess with the bike up on the center stand the downhill direction was into the motor....
Fuel was making it into the intake manifolds and filling up on top of the cylinder --- whenever this happens, if not already done, should assure the crankcase oil has not been contaminated with gasoline. May use the sniff test for gas aroma, and check for really thin oil, and sometimes the indicated oil level itself will rise due to infusion of gasoline. If there's any doubt, should drain and replace the oil and also install a new oil filter. As known, running an engine with crankcase oil contaminated by fuel intrusion risks substantial engine damage.
Fuel overflow may also reach the carb bore and travel backward toward and into the airbox, and from there drain down through the crankcase vent tube directly into the crankcase.
Floatbowl overflows are supposed to prevent this condition of gas getting into the carb throat, but the overflows are sometimes obstructed or simply unable to cope with a massive fuel leak through the float needle/seat interface.
Good Luck!
