will not idle
- bubba_d
01 Mar 2008 20:21 #197839
by bubba_d
1977 kz1000.
will not idle was created by bubba_d
i recently rebuilt my accel pump. replaced intake boots. replaced needle and seat in all 4 carbs. now bike will not idle. runs great under acceleration. will die if choke is applied. didnt do this before, but didnt run as well before. only thing i can think of is one of the springs in the kit was heavier than the oe spring. i used the heavy one. think this is my problem.
1977 kz1000.
- kzwolfsr
- Thank you received: 16
01 Mar 2008 21:23 #197850
by kzwolfsr
Original man of the Caribbean
Replied by kzwolfsr on topic will not idle
either air leak causing mix to be to lean, idle adjustment not done or dirty air or fuel filter or running rich and getting that air on acceleration. Try the spring thing, put the other one back in and see what happens, but I doubt thats the prob, but it will cause uneven mixtures in the cylinders, I am guessing. Check your cable adjustments and the idle adjustment and check back.
- bubba_d
02 Mar 2008 07:00 #197907
by bubba_d
1977 kz1000.
Replied by bubba_d on topic will not idle
cable adjustment is good. idled fine before. would start right up with choke on. now have to give it some throttle to start. any advice would be appreciated...wg?
Post edited by: bubba_d, at: 2008/03/02 15:01
1977 kz1000.
- bubba_d
- wiredgeorge
02 Mar 2008 15:34 #198005
by wiredgeorge
Replied by wiredgeorge on topic will not idle
wg? Dunno what you did. It wasn't the accelerator pump kit for sure. Won't idle means that the idle circuit is messed up. Since I have no idea what type carbs these are, I can only suggest adjusting either the pilot fuel mixture screws or air screws to 1 1/2 turns out from lightly seated. You should also check the float levels and last, thoroughly clean the pilot system. Are the vents clear?
The pilot system isn't getting the proper air/fuel mix so it won't idle. You did enough things while in there that most anything I mentioned might have mucked up something.
- bubba_d
02 Mar 2008 19:01 #198052
by bubba_d
1977 kz1000.
mikuni carbs round slide no diaphrams. vents are clear. float levels... wait a minute. think thats where i might have done something. i adjusted them... a little. if im my fuel level is not high enough it will not hit the pilot jets. this explains it... right...
Post edited by: bubba_d, at: 2008/03/02 22:02
Post edited by: bubba_d, at: 2008/03/02 22:12
1977 kz1000.
- kzwolfsr
22 Mar 2008 19:52 #201642
by kzwolfsr
Well?
