'00 zr750s carbs fit '82 GPz750 ??
- hannah1
26 Feb 2008 05:10 #197030
by hannah1
'00 zr750s carbs fit '82 GPz750 ?? was created by hannah1
Does anyone know if these carbs ('00 ZR750s) are usable on my '82 GPz750 ? Don't need to buy more stuff I can't use . Thanks .
- Paling1
27 Feb 2008 02:01 #197187
by Paling1
KZ700-A1 (1984)
525 chain conversion; Dyna 2,2 ohm coils; Taylor plugwires; Stainless steel ZR-7 exhaust ; Remus muffler.
Plans: GPZ cams, ported head, 17 inch wheels, EFI....
Replied by Paling1 on topic '00 zr750s carbs fit '82 GPz750 ??
I think they would work fine on your bike. But you definately need the ZR750's carbboots to go with the carbs.
Whereas the cylinderhead of the ZR750 is almost the same as the old KZ750's, the carb-spacing is a little different. So the carbboots from the ZR750 are at different angles than your stock carbboots...
KZ700-A1 (1984)
