- Thank you received: 5
anyone ever replace a broken overflow nipple?
- fixer5000
25 Feb 2008 02:43 #196884
by fixer5000
1978 kz650b pretty much stock
massachusetts
anyone ever replace a broken overflow nipple? was created by fixer5000
got a set of e bay carbs with one broken overflow nipple. any ideas on replacing this?
massachusetts
- The Milkman
- Thank you received: 194
25 Feb 2008 05:37 #196894
by The Milkman
Replied by The Milkman on topic anyone ever replace a broken overflow nipple?
I do believe I have a bowl or 2 "floating" around out in the garage from my custom . I'll check this afternoon. Buy kawasaki doesn't list a part number for the bowl, but I'm guessing they are the same. If I do I'll PM you for your address.
If the weather was nicer I'd hand deliver it,, . I WANT TO RIDE!!!!!!
Post edited by: The Milkman, at: 2008/02/25 08:44
- Thank you received: 797
25 Feb 2008 05:53 #196898
by 531blackbanshee
Replied by 531blackbanshee on topic anyone ever replace a broken overflow nipple?
i have heated an old mikuni(dirt bike carb)and removed the brass nipple.i then pressed it back in to the bowl,on the acc.pump circuit for my z1r.been workin every since.
- FloridaBiker
- Thank you received: 4
26 Feb 2008 06:06 #197037
by FloridaBiker
Replied by FloridaBiker on topic anyone ever replace a broken overflow nipple?
The two part epoxy from Autozone/Advance auto parts stores works for this.
The epoxy bonds to the carburetor and is gas proof.
I have saved many carbs with it.
Yesterday I repaired a broken float hinge mounting and a cracked float bowl.
It is amazing stuff.
- The Milkman
26 Feb 2008 08:01 #197054
by The Milkman
PM sent.
- fixer5000
26 Feb 2008 13:09 #197119
by fixer5000
massachusetts
Replied by fixer5000 on topic anyone ever replace a broken overflow nipple?
milkman...thanks for the offer but i do still have my old carbs so i could use those for a spare bowl. the advice on heating it to remove it sounds valid to me i think ill try that and have my machinist buddy whip me up a new nipple for it.. again thanks for the offer milkman,...steve
massachusetts
- peter1958
- Banned
- Thank you received: 198
02 Aug 2011 20:45 #466449
by peter1958
Replied by peter1958 on topic anyone ever replace a broken overflow nipple?
Just what i was looking for. ty
- MFolks
- Thank you received: 540
02 Aug 2011 23:36 #466488
by MFolks
Replied by MFolks on topic anyone ever replace a broken overflow nipple?
Maybe some Red Loctite that's used for bearing retention will work. A small drop & then push the new part in the bowl should work.
