worth?. z1r1000 carbs?
- RollingStock
24 Feb 2008 10:17 #196672
by RollingStock
73 z1900 street nitrous drag bike(powered but honda)
83 kz750 turbo street fighter project
worth?. z1r1000 carbs? was created by RollingStock
just wonder what my working z1r 1000 carbs are worth.. these are the 28mm pumper carbs. jeted, new bowl gaskets.. i do not have the diaham for the pump.. but other than that they worked great... these came off a running bike...
can post pic if needed... what u think these would sell for?.
also have a set of kz1000 carbs that need new bowl gaskets...
Post edited by: RollingStock, at: 2008/02/24 13:18
- Sandy
- Fly High,Tony
- Thank you received: 13
24 Feb 2008 10:36 #196683
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic worth?. z1r1000 carbs?
Hmmmmm....$75-$100...maybe even more,depending on condition.
I've got a set here that are in desperate need of a cleaning(soaking),and those ones I'd sell for about $50
There was a set on the bay that were listed as "29mm" and THEY sold for over $170...but that's a whole other story.I put up a post about it.
tinyurl.com/2aypbm
tinyurl.com/2aypbm
1977 KZ1000 A-1
- RollingStock
24 Feb 2008 10:56 #196696
by RollingStock
Replied by RollingStock on topic worth?. z1r1000 carbs?
- Sandy
- Fly High,Tony
24 Feb 2008 11:21 #196704
by Sandy
1977 KZ1000 A-1
Yup...I'd say somewhere around the $100 mark.
They look like they're in nice shape.
What are the insides of the bowls like?:whistle:
1977 KZ1000 A-1
- RollingStock
24 Feb 2008 11:41 #196711
by RollingStock
- Sandy
- Fly High,Tony
24 Feb 2008 11:55 #196720
by Sandy
1977 KZ1000 A-1
They would still need an overhaulin,but yes...not too bad at all,for sure.
1977 KZ1000 A-1
- kaw-62046
26 Feb 2008 17:57 #197156
by kaw-62046
Replied by kaw-62046 on topic worth?. z1r1000 carbs?
those my be off a 1980 Z1R ,1978 Z1R carbs were not pumpers.
- CptEDIV
26 Feb 2008 18:31 #197159
by CptEDIV
1979 KZ 650 D2 \"Midnight\" blue.
Replied by CptEDIV on topic worth?. z1r1000 carbs?
Pumpers? Does this mean they have the accelerator pump?
Just curious,
Just curious,
- kawsakiman
- Thank you received: 6
26 Feb 2008 19:39 #197168
by kawsakiman
Replied by kawsakiman on topic worth?. z1r1000 carbs?
just wondering?
do pumpers work on all 4 carbs or just #2?
- Bad Kaw
- Flying Squirell
26 Feb 2008 20:58 #197174
by Bad Kaw
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
Replied by Bad Kaw on topic worth?. z1r1000 carbs?
I cleaned out my 'stash' of spare carbs last year and threw 'em up on eBay. I got rediculous money out of them (well, I thought it was rediculous). I had set that was damaged, a set that was incomplete, a set that was stock, a gummed up set...they all went for money that I didn't think they'd bring, so, I think you'll do fine.
Good luck,
-KR
Good luck,
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
- wiredgeorge
27 Feb 2008 06:06 #197191
by wiredgeorge
Replied by wiredgeorge on topic worth?. z1r1000 carbs?
Z1R carbs don't have an accelerator pump.
for Kawasakiman - The pump is on #2... it draws gas from the #2 bowl and sends it out a hole on the edge of the bowl through the venturi to the nozzle in the venturi. Similarly, the pump sends gas out through the small fuel lines to the other three carbs, up through the bowl edges into the nozzles of those carbs. All four carbs have nozzles in the venturi where a squirt of gas comes out when the throttle is twisted. The gas moves because of the pump diaphragm and not engine vacuum
Post edited by: wiredgeorge, at: 2008/02/27 09:09
