Jetting help!
- kzmarvo
Watch it folks,i have sticky fingers when it comes to a nice looking set of handle bars:)
- kzmarvo
- wiredgeorge
Post edited by: wiredgeorge, at: 2008/02/21 09:15
- kzmarvo
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
Are the pods Emgo's or K&N's?
Do you know what pipe it has and I'm assuming by open you mean no baffle?
15 pilots (stock) and 115 mains might work out OK but it would be nice to know what is in there before recommending another jet size. The mains should be 102.5's if it's an LTD, MKII still stock which were very lean to begin with IMHO. Shafty's had 112.5's stock. How lean is it at idle? Does it pop back through the carbs?
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- kzmarvo
- wiredgeorge
- KZ_Rage
Its a Star open-header but will soon be a Kirker open, no baffle. And the air filters are not k&N's. And it is a chain drive.
If it were me, I'd pop a set of 17.5's pilots in and the 115's or 117.5's. You can always try the 15 pilots first but I think you're going to have too large of a transition from 15 pilots to anything larger than the 115 mains when you roll it on and end up with a flat spot in the mid range. Jetting is tweaking after you get in the basic range, there is no spot recommendation on unless you just get lucky. Stock setups are so much easier as you can address the factory lean with no more than 1 or 2 steps in jets. Open baffle 4 to 1's are pretty tricky when trying to jet it for top end (over 6G). Your plugs are going to tell you the most about getting it jetted right unless you have access to a dyno.
If you want the best chance of getting it as close to right as possible be sure everything else is good (valve clearance, compression, spark) and you may have to replace the needles so as to have adjustable clips as a lot of the 1980 and later carbs had fixed needle heights. This will help you tweak the mid range.
I will always be learning carb setup especially on needle jet sizes and performance results. Carb setup for peak performance on any bike with engine, intake or exhaust mods is a learning curve that has no end to it, have fun, drink a beer or six after you get frustrated and try again later! :laugh:
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- wiredgeorge
- KZ_Rage
Why re-sync the carbs after changing jets? Just curious.
Well I have found that just like year to year they seem to easily come out of balance for no good reason, it wouldn't hurt to do a quick check to be sure nothing got knocked out of adjustment or especially with older boots created a vacuum leak by pulling and reinstalling them. Just good a reassembly practice to get in the habit of IMHO else you might be blaming the new jets when it is a leak or adjustment issue.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
