- Thank you received: 1
Throttle cable lengths?
- Afrosemite
16 Feb 2008 15:38 #194992
by Afrosemite
\'78 Kz650d sr
Throttle cable lengths? was created by Afrosemite
So I concluded that my throttle was binding because the "pull" throttle cable was binding up because it was fraying. I thought I would just switch it out for the "push" cable that is still in good condition but it's not long enough. This make sense to anyone else or am I just doing it wrong?
\'78 Kz650d sr
- KawiConvert
- Thank you received: 4
24 Feb 2008 21:03 #196859
by KawiConvert
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
Replied by KawiConvert on topic Throttle cable lengths?
It can be the cable or the housing. New cables are only about 15.00, just replace it and save the headache. I have a friend who went cheap by rigging a new throttle cable up and when he bump started it it took off and he ended up wrecking his front rim and a signal. So instead of out 15.00 he was out about 200.00. Your millage may vary however.
- BSKZ650
- Thank you received: 14
25 Feb 2008 05:13 #196890
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Throttle cable lengths?
they are not the same length, if you go to z1 read where it says to use another part number for the push pull, and buy two new cables
- Afrosemite
25 Feb 2008 07:38 #196908
by Afrosemite
\'78 Kz650d sr
Replied by Afrosemite on topic Throttle cable lengths?
Already got the new pull cable, I didnt measure or anything but it fit and the old push cable didn't so I am assuming it is longer
\'78 Kz650d sr
