WOW What a difference! (Jetting)
- ran429
- Master of FREE rides!
While the bike ran well with the stock primary jets (#62) it still took forever to warm up and idle on its own.
Today i installed the 70's and reassembled the bike, I let the fuel get primed into the carbs for a minut then started it.
I immediately noticed that shortly after starting it I now need to plunk the Choke handle to the almost off position or it will choke out.
I am very happy with the new jets and took a video of it going through the RPM ranges. I am satisfied at how it does so with ZERO flat spots!
Thank You WiredGeorge for the insight on Jet sizes and carb adjustments and Thank You Z1 Enterprises for having a great Business and Services.
Video shortly.
- ran429
Its clear that the bike runs so much better, i let it cool awhile with a fan blowing on it, i noticed that the idle is really low at 1K until a couple minutes after i start it, isnt it supposed to be at 2.5K?
I just turn it up a bit until its a t operating temp and then manually turn it back to 1.5K and its all good.
- ran429
Only went to 40 (posted limit) and cant believe what a difference a couple holes can make.
First time i have ridden the bike with it running smooth, cant wait to hit the freeway onramp and see whats "Really Goin on!" lol! :whistle:
I wish i lived in an area that has 75Mph interstates like back east to down south and southwest on my drive from Chicago to Arizona.
I would like to see how it runs at speeds now lol!
- dannyg40
- ran429
if i run it at that then the starter clutch makes too much noise for me, with it at 1.5 i cant really hear anything and it seems to me to be running better than it ever has.Warm idle speed on all 4's are generaly around 1K. + or - 100 RPM.
Havent heard anything of running it at 1K as a standard really.
EDIT: I just checked my Manual and it calls for 10 degrees top dead center at idle of 1050rpm. so its set proper.
Post edited by: ran429, at: 2008/02/16 20:28
- Bluemeanie
- Thank you received: 14
- ran429
Hey ran, your idle is set at 1.5 but manual says 1050? That's a 450rpm difference, how is it set proper? As danny says most standards idle at about 1000rpm +/- If it makes noise at 1000 +/- you might be hearing your timing chain because of looseness, carbs not synced, etc. Glad you finally got it running smooth. Run it out to a back road and let her rip!!
its at 1.5, right in the middle of 1K and 2K that was a typo.
see video and you will see where it runs. if it goes any lower the bike wont run correct no matter what i do to it.
If i have it running at 1050 RPM's & 10-deg b4 TDC it wont run quiet due to the stupid worn starter clutch noise.
Maybe i should roll it off a hill and buy a brand new bike instead.
I will if i cant get the motor running where its supposed to.
Post edited by: ran429, at: 2008/02/16 23:36
- jmargrav
1982 KZ750-E3
Lariamie Wyoming GO WYO!
- Bluemeanie
- Saki Jockey
I like it, I like it a lot.
Rob A.
550 A4
GTA,
Ontario, Canada
