- Thank you received: 1
Petcock Problem
- H2RICK
- Is this a fun bike, or what!!!
14 Feb 2008 08:05 #194542
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Petcock Problem was created by H2RICK
I'm not sure if this is the right forum for this subject or not.....but the petcock is connected to the carbs, so.....
If it's not the right forum, could the board admin folks move it to the correct forum for me ??
My problem is that the petcock on my KZ650C2 has a slight weepage of gas around the outlet elbow fitting. I never realized that this elbow could be moved....or removed until I started investigating the leak. Strange design. Has anybody used some kind of sealant or oring to prevent gas leaking out of this area ?? All help/experiences greatly appreciated.
- JMKZHI
- Thank you received: 48
14 Feb 2008 09:23 - 03 Dec 2008 20:44 #194550
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 03 Dec 2008 20:44 by JMKZHI.
- BSKZ650
- Thank you received: 14
14 Feb 2008 09:31 #194552
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Petcock Problem
this is not the best fix, but they do sell gas tank mender, its a epoxy, it holds up well, may not look the best but it will seal
- RonKZ650
- Thank you received: 240
14 Feb 2008 10:14 #194567
by RonKZ650
Replied by RonKZ650 on topic Petcock Problem
JB weld works for this. The nipple is not supposed to pull out or be loose fit, it's meant to be a tight fit. JB weld holds up indefinately to gas.
- H2RICK
15 Feb 2008 19:58 #194825
by H2RICK
Replied by H2RICK on topic Petcock Problem
Thanks for the suggestions, gents. I'll have to hunt up a tube of JB Weld or some other gas proof epoxy and give it a whirl. This is a REALLY dopey design, IMO, because that elbow is made out of diecast zinc and is VERY fragile. Grrrrr......
- JMKZHI
16 Feb 2008 06:11 - 03 Dec 2008 20:46 #194866
by JMKZHI
del
Last edit: 03 Dec 2008 20:46 by JMKZHI.
