- Thank you received: 337
cafed650 time to jet spot on!
- bountyhunter
Nope, not supposed to do that.This is a great thread and has got me thinking....
Is it normal to have strong differences in performance that require carb tweaking over the span of a few hours.
Sometimes, after a great ride in before work, after work I can only get my bike to run smoothly by adding choke. :huh: Normal???
- scumbag
- Lewd, Screwed, and Tattooed
scumbag wrote:
So I have yet to investigate what clip position the needle has but the jetting info you gave is exactly what I am running right now.
Some more info that I have on how the bike was running before I pulled the carbs. When ever a lot of throttle was given the bike would bog or if the throttle was bliped the bike would bog down if not die. the bike would run great from about half throttle onward but the bottom end was lacking.
That EXACTLY describes how mine ran after adding new headers. The fix: lower the clip on the jet needle to give maximum richness.
Understand why: from about "1/2 throttle up" the piston raises fully and the needle is all the way up and not restricting or metering flow. The amount of fuel is determined mainly by the size of the main jet.
But, at lighter throttle openings where the piston is only partly raised, the position of the needle with respect to the piston has a HUGE effect on fuel flow.
Cool...done and done...now to see if it runs any better
oh and how many turns out on the air(or is it fuel) screw on the bottom...I cant find my manual
sept.1976 kz650
1980 kz650
- wiredgeorge
- Qdude
- It is all good.
- Thank you received: 1
77 KZ 650 C1.
77 KZ 650 C1.
