cafed650 time to jet spot on!
- scumbag
- Lewd, Screwed, and Tattooed
The exhaust is fairly open with minimal baffling and I have a K&N in the airbox...yes the airbox is still there! haha...might consider pods if I get sick of putting the carbs on and off!!!
So...jet opinions...
when I get the carbs off I will tell you whats in there right now.
-Brian
sept.1976 kz650
1980 kz650
- bountyhunter
- Thank you received: 337
Ok so I am tired of the bike running off and its time to get it jetted spot on...
-Brian
I'm no expert, but I know reducing the back pressure with "open baffling" will make it run severely lean. They usually say go at least +1 richer main and pilot jet for a start. On mine, I also had to go +2 slots richer on my needles to get decent throttle response (YMMV).
Adding pods will probably screw things up completely.
The best info I have ever seen giving a basic procedure to dial in jets and CV carbs is here:
www.factorypro.com/tech/carbtun.html
Post edited by: bountyhunter, at: 2008/02/14 12:59
- wiredgeorge
After the words about dialing in the bike's jetting, first thing I figure out is that there is NO info on current jetting and no info on how the bike performs with this jetting. I have to make an assumption we are talking about non-pump VM24s with pilot fuel mix screws?
When you look down through the muffer and see "minimal baffling" this is normal with ANY 4 into 1... mostly looks wide open. MOST, if not ALL 4 into 1 systems made for a KZ are perhaps described best as cosmetic noisemakers that don't really flow much better than a stock system. If you are using a K&N filter in the stock airbox, try the stock jetting I guess and see how it works.
- ran429
- Master of FREE rides!
I will get back to you on them.
- scumbag
Well the main jets are 102.5's and the pilots (the jet right next to the main)have a 50 on them. Have not looked at were the clip is on the needle but will look this eve.
thoughts wired?
sept.1976 kz650
1980 kz650
- anarki650
- Thank you received: 5
Probably doesn't mean much to you right now since you've got a K&N drop in, but if you do opt with pods at least you'll know a good baseline.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- scumbag
sept.1976 kz650
1980 kz650
- mariozappa
- Thank you received: 8
1977 KZ650C1
and the KZ650/KZ750 Conversion
- Bluemeanie
- Thank you received: 14
- scumbag
I can't find it now but WG wrote about these carbs and I believe he mentioned that certain carbs had a #50 restrictor on top of the pilot jet, so yes there should be something underneith it. He says you can leave (save it) the restrictor off.
Crazy...would love to hear more
sept.1976 kz650
1980 kz650
- wiredgeorge
- Qdude
- It is all good.
the needle tip (needle point, lol) to butted end,
or the butted end to needle (point)?
77 KZ 650 C1.
77 KZ 650 C1.
