carb issue
  • boomboom45
  • boomboom45's Avatar Topic Author
carb issue
13 Feb 2008 01:37
#194328
i need some help, again. i noticed on a ride the other day that my carbs seem to bog down at about 65 and when i park her im leaking gas out the #2. any suggestions?
Re: carb issue
13 Feb 2008 01:50
#194330
Possibly crud in float needle/seat interface. :)
  • boomboom45
Re: carb issue
13 Feb 2008 01:51
#194331
would that cause the bogging down also?
Re: carb issue
13 Feb 2008 02:42
#194333
Uncertain, as bogging may result from several things, and perhaps not carb related.
But one theory would be possibly of leaking float needle/seat interface causing too high fuel level in float bowl resulting in over-rich mixture. :)
  • boomboom45
Re: carb issue
13 Feb 2008 06:01
#194367
what if i had set the float needle? to high, would that cause both problems?
  • bountyhunter
  • bountyhunter's Avatar
Re: carb issue
13 Feb 2008 09:27
#194390
It could. First thing to do is measure the resting fuel levels in the bowl and set them right.
If you still see flooding, check the needle valve and seat for that carb.
  • ran429
  • ran429's Avatar
  • Master of FREE rides!
Re: carb issue
16 Feb 2008 09:53
#194899
check the drain plug O-ring on the bottom of the float bowl also. mine were bad last year and they leaked alot.
what he said above, some crud in the needle seit will do that also.
dont use compressed air in your carbs without removing any diaphrams first.
Re: carb issue
16 Feb 2008 10:33
#194915
boomboom45 wrote:
...carbs seem to bog down at about 65 and when i park her im leaking gas out the #2.
leaking gas out the #2 --- does this mean fuel is coming from the overflow nipple on bottom of the float bowl? Usually, each nipple has a rubber tube attached leading to underneath the bike, so overflow is deposited onto the ground or garage floor (instead of onto the motor underneath the carbs).
As noted by ran429, gas leak may be from another source such as faulty o-ring on drain plug.
Leak could also be fuel getting past float bowl gasket (faulty gasket or loose float bowl screws), or deformed float bowl flange (usually repairable). :)
