Hose Problem
- j_bizach
11 Feb 2008 19:45 #194104
by j_bizach
Hose Problem was created by j_bizach
I just bought a 81 kz550 and am in the middle of fixing it up but ran into the problem that a have two small lines ( they appear to be vacume lines as they come out of area of the carb where the slide goes up and down and two larger hoses which appear to be fuel lines. The petcock is stock and im confused on where all these hoses go. Ill try to get some pics up tomarrow. If some on could help me or suggest a repair manual with detailed diagrams i could really use the help.
- CptEDIV
- Thank you received: 1
11 Feb 2008 20:22 #194123
by CptEDIV
1979 KZ 650 D2 \"Midnight\" blue.
Replied by CptEDIV on topic Hose Problem
Is it a vacuum operated petcock? I think I know what two lines you are talking about, and I don't even have them hooked to anything... What are those? I don't think they are vacuum..
- j_bizach
12 Feb 2008 10:04 #194205
by j_bizach
Replied by j_bizach on topic Hose Problem
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
12 Feb 2008 11:46 #194226
by The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Replied by The Gringo on topic Hose Problem
Okay I had to go look at one of my 550's to get this figured out. Starting from the top of your pic, the first hose you have outlined in green is the vent hose and does not connect to anything just route it over the airbox somewhere. The second hose between carb #2 and #3 that you have outlined in red is the fuel inlet, this gets connected to the larger of the 2 outlets on your petcock. The third hose that you have circled in red is a vacuum hose that connects to the smaller outlet on the petcock. The fourth hose you have circled in green is the vent hose for the #3 and #4 carbs again it connects to nothing just run over the airbox just like the first hose.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- j_bizach
12 Feb 2008 16:20 #194274
by j_bizach
Thank you very much you have made my life a lot easier
