- Thank you received: 250
28mm (VM28SC) carbs plus mods.
- kzstreetfighter71
- Atlantic West Coast
Main Jet 112.5
Air Jet 1.0
Needle Jet O-8
Jet Needle 5J9-2 (last number is the clip position)
Throttle valve (slide) 1.5mm cutaway
Pilot Jet 17.5
Air Screw setting 1 1/4 turns out
is there any sugestions on setting up these carbs to run at full potential?
- kzstreetfighter71
- KZ_Rage
- Kentucky Bourbon Barrel Ale
- Thank you received: 19
Do you have a local shop with a dyno? Best way to actually "see" the results of carb changes.
Post edited by: KZ_Rage, at: 2008/02/11 09:57
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
2006 ZG1000A6F (Totaled)
2001 ZRX1200R (Sold)
- kzstreetfighter71
- KZ_Rage
the bike ran but not well, the old owner was a ??? weeknd mecanic at best, the main jets that wer on her wer 15, the plugs looked fine, more lean than anything, iv replaced just about every thing, i would like to know if 18 would be ok as main jets? with the k&n, ignition,coil,leads and exhaust or will i go for smaller ones?
Mains are 115's now and the pilots are 17.5's?
Is that V&H baffled or open?
As far as a bench setting to start out, 115's, 17.5's and the clip in the middle notch would be a good start. I'm still tweaking mine and I have a slightly opened MAC, pods, Dyna coils, std. elec. ign., 120's, 20's and middle clip, it might be a bit rich but I'm waiting for the weather to break so I can get a better idea.
When I get it where I'm close as I can get it by my methods then I'll take to Pro Stock here locally and have it dyno'd. Not trying to make it a hot setup right now, maybe when the day comes to take the head off but I'd like to know anyway.
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
- kzstreetfighter71
- KZ_Rage
1979 KZ1000E1 SOLD!
1984 KZ550F2 SOLD!
