Throttle Issue
- Afrosemite
Throttle Issue
09 Feb 2008 13:02
So I finally got my registration after sitting around in the Santa FE DMV for like three hours. Had a strange problem on the the way there and back though. I've checked around the forums to see if this had already been solved but I couldnt get a good idea. Here goes:
The throttle is acting funny. It works fine when I'm moving but when I want to slow down (engine brake) or am sitting at a stop it acts like the throttle hasnt been released. The handle goes back normally but it may still rev real high. I can fix the problem but just quickly "popping" the throttle which has led me to believe that I just need to take the cable off and lube it.
This sound about right? or could something more sinister be amiss?
tangent question = Best way to lube the cable without one of those handy cable lubers?
\'78 Kz650d sr
- The Milkman
Re: Throttle Issue
09 Feb 2008 13:11
It sounds like your cables may be adjusted too tight. You have to have a little slack or they will bind. Your repair manual will explain how to set it up right.
- Afrosemite
Re: Throttle Issue
09 Feb 2008 13:15
repair manual may not be here for a week or two.
Is this particularly damaging to the engine? Can't see how it would be but I'm also an idiot so I tend not to go by my idea of "can't see how ______" could be bad
\'78 Kz650d sr
- The Milkman
Re: Throttle Issue
09 Feb 2008 14:03
The easiest way to check it:
Without having the bike running, look underneath the gas tank at the linkage as you are slowly rotating the hand throttle, there should be a slight hesitation before the linkage starts to move. The return cable should also have some slack in it so the throttle can fully seat against the stop screw. If there isn't a tiny bit of play in both cables it will bind. To put more slack in the cable, loosen the lock nut on the adjustment and screw the adjuster in a little bit. Then tighten the lock nut and recheck for play.
Hope this helps.
Ride safe.
Hope this helps.
Ride safe.
- Bluemeanie
Re: Throttle Issue
09 Feb 2008 15:18tangent question = Best way to lube the cable without one of those handy cable lubers?
Simple way is to unhook cables at throttle and wrap small baggy tightly (use rubber band, etc) filled with favorite lube. Hang unside down and lube will work it's way down. Stop when lube starts dripping out from other end.
- Afrosemite
Re: Throttle Issue
12 Feb 2008 13:50
So the cables already had some slack in them. I haven't lubed the cable yet but I am starting to be worried that the cable isn't the problem.
Sometimes if I just barely tap the throttle and pull in the clutch it will just rev up real high. I can get it to stop by popping the throttle a time or two but it does it often. A couple of times at stop lights I have just turned it off to keep from over-reving right there at the light. Get's real annoying with the "cruise control" effect too.
It was fine about a week ago but it's been doing this the last two days.
I absolutely don't have the money to rebuild these carbs so somebody tell me it's something else
Post edited by: Afrosemite, at: 2008/02/12 17:24
\'78 Kz650d sr
- Bluemeanie
Re: Throttle Issue
12 Feb 2008 14:27
Try this, unhook BOTH cables from the carbs and start it up. If problem goes away you know it's the cables. If it's still there then start looking (with engine off) at throttle operation, something might show up.
- Afrosemite
Re: Throttle Issue
12 Feb 2008 14:59
well, I may have fixed it?
I panicked and went to my old method of "spray WD40" on everything. Down the cables, on the linkages, really anything that looked like it moved, could move, or could be motivated to move.
Now it snaps back closed quite loudly (the carbs) and the problem seems to have stopped. We'll see if it stays fixed . . .
\'78 Kz650d sr
- Bluemeanie
Re: Throttle Issue
12 Feb 2008 17:05
I'll bet the cables were binding, try the baggie method because WD40 will evaporate and not leave enough lube behind.
- BSKZ650
Re: Throttle Issue
13 Feb 2008 05:07
use just about anything but wd 40, it was made to be a water displacement hence WD not a oil
Post edited by: BSKZ650, at: 2008/02/13 08:07
77 ltd1000, current rider
76 kz900, just waiting
