Re-racking a set of flatslides?
- z19OO
15 Oct 2005 15:10
I'm getting a set of 36mm carbs that were on a zx1000......has anyone reracked these carbs before? Is it easy or do I need to buy extra parts?
1975 z1 900
1979 kz650b
1979 kz650b
- dgfischer
Re: Re-racking a set of flatslides?
16 Oct 2005 06:28
I have re racked a set of VM 33mm for a CB 450 (2 cylinder). I had to make a new mount for the carbs, re machine the shaft for the slides and choke shaft to work on the 2 carb assemblys. I used the inner 2 carbs(thats where the throttle linkage was) and had to plug the fuel feeds on the out sides of the carbs.
Daniel
Daniel
- z19OO
26 Oct 2005 15:37
The carb spacing on the zx1000 carbs are 77-85-77 kz's are 77-93-77. Mikuni makes both.......i'm wondering if its a mater of moving bolts around?
1975 z1 900
1979 kz650b
1979 kz650b
