- Thank you received: 1
Air Ducts
- CptEDIV
07 Feb 2008 13:37 #193312
by CptEDIV
1979 KZ 650 D2 \"Midnight\" blue.
Air Ducts was created by CptEDIV
Is there a trick to connecting the air ducts between the carb and the airbox?? Its 79 KZ 650, and I've been trying to get them squeezed through the airbox hole for about an hour now, and am ready to pull my hair out.
Thanks,
Thanks,
- Bluemeanie
- Thank you received: 14
07 Feb 2008 13:50 #193316
by Bluemeanie
Replied by Bluemeanie on topic Air Ducts
I install mine through the air box also but trying to squeeze old hard boots is almost impossible. There have been many chats here about boiling them in water, microwaveing (tried it, melted!) laying in sun, etc. Now I'm gonna tell you what you know, but don't want to hear.... by some nice new SOFT
carb boots
from Z1!
Post edited by: Bluemeanie, at: 2008/02/07 16:51
- andoman
07 Feb 2008 13:51 #193317
by andoman
Replied by andoman on topic Air Ducts
When you are done pulling out your hair, just buy pods and re-jet. I have hated air boxes my entire riding life. The rubber gets hard and then routine maintenance becomes a nightmare.
Or it could be that I am a Lazy Sack...
Seriously, I think you can soften them up. I have soaked hard rubber parts in Armor-all with some success. The silicone in Armor-all also makes things slippery and they tend to slide into place easier.
I second the brand new boots. They will work, well, like new!
Good luck!
Post edited by: andoman, at: 2008/02/07 16:52
Good luck!
- OnkelB
- Thank you received: 80
07 Feb 2008 13:56 #193319
by OnkelB
77 KZ 650 B1, 82 GPz 1100 B2.
Replied by OnkelB on topic Air Ducts
What I used to do (before fitting a Henry Abe air filter) was to install the air ducts through the airbox. Remove the air filter, stick the duct down the airbox and through the hole - get the groove on the duct started and use a small screwdriver to pry around the groove on the outside of the airbox while having one hand down the box to hold the duct from behind.
If the ducts are hardened a minute or two in hot/boiling water will make them soften up, install them while they´re still warm.
Wow, you guys are fast... :S
Post edited by: OnkelB, at: 2008/02/07 16:58
- CptEDIV
07 Feb 2008 14:03 #193321
by CptEDIV
Replied by CptEDIV on topic Air Ducts
That was fast... I think I want to rejett and get pods on it, but for now I just want to get the old ones back on so I can get around. They won't melt in boiling water will they...? Trying to think what my grandma would say if she came home while cooking carb parts in her pot. Haha. I think I'll try boiling then use some WD 40.
Thanks,
Thanks,
- OnkelB
07 Feb 2008 14:24 #193326
by OnkelB
No, they won´t melt, at least not in a minute or two, but they´ll only stay soft as long as they´re warm, once they cool off they´ll harden again so you might want to do one or two at a time.
- CptEDIV
07 Feb 2008 15:21 #193333
by CptEDIV
Thanks a ton for the help. I boiled some water and held the hard part in the water for about 45 seconds, ran outside and they went in easy as... well, really easy. After a couple minutes they are already hard and in perfect. If it wasn't so dreary out, I'd be on the bike and going for my first ride in about two weeks. I'd definitely recommend this method. Thanks again,
- Bluemeanie
07 Feb 2008 16:59 #193346
by Bluemeanie
Now that wasn't too bad, huh?
- OnkelB
- N0NB
- Blue handles better
08 Feb 2008 08:03 #193444
by N0NB
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
Replied by N0NB on topic Air Ducts
Rather than a screwdriver or other sharp metal object, I use an old tooth brush that has a wide blunt plastic handle to help work the boot into place. So far, so good.
Nate
- bill_wilcox100
- Thank you received: 5
08 Feb 2008 16:01 #193529
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic Air Ducts
I'm with Bluemeanie on this one.
In the end I just bought a set from Z1 because it was taking the all fun out of wrenching.
Best of success!
Best of success!
Upgrades:
Montreal, Canada
- jdburke
08 Feb 2008 20:26 #193545
by jdburke
John
1978 KZ 1000A2
N.E. Oklahoma
Replied by jdburke on topic Air Ducts
If you don't get them on before they cool, you can warm them back up with a hair dryer or a heat gun on low setting.
John
1978 KZ 1000A2
N.E. Oklahoma
