Replacement carbs. What fits?
- Kraygh
05 Feb 2008 12:52 #192960
by Kraygh
Replacement carbs. What fits? was created by Kraygh
I need some experts to bottom-line this for me.
I have a 1980 KZ750 LTD4
I would like to replace the stock carbs (keihin) with something that has parts that are more readily available.
What is a direct fit for this bike?
I heard people say it depends on the application... so I'll try to be more informative:
I do little highway traveling. Just short tours around town.
I'd prefer something that doesn't need constant tweaking to get to perform at it's peak. (i.e. reliable.)
And good parts availability, just is case.
Thanks in advance for any info that helps!
- wiredgeorge
05 Feb 2008 13:44 #192975
by wiredgeorge
Replied by wiredgeorge on topic Replacement carbs. What fits?
The only direct fit is a CV34 because the carb holders are unique to that application. If you change the carb holders and throttle cable, you can use BS34 or BS32 Mikuni assemblies. If you change the carb holders, throttle cable and either adapt the airbox to carburetor rubber connectors (or use pods), you can use Mikuni VM24, VM26, VM28, VM29 or vm33 carburetors.
- Kraygh
05 Feb 2008 14:36 #192983
by Kraygh
Replied by Kraygh on topic Replacement carbs. What fits?
Thanks for the quick response.
I have no problem with changing boots or cable and air intake isn't that big of a deal to play with.
But with all these choices, which is best and why?
- wiredgeorge
07 Feb 2008 10:56 #193277
by wiredgeorge
You have unique priorities that will make one man's best bet your worst nightmare and vise versa. Do some searching through the archives in this forum area... I am sure this will lead you to being able to match your priorities and pocketbook with specific types of carburetors.
- dadams7161
- live to Ride Lifes Better on the Road in the wind
09 Feb 2008 00:42 #193566
by dadams7161
1982 KZ750-M1 CSR Twin
3rd Owner of this Jewel
Before and After Photos
Replied by dadams7161 on topic Replacement carbs. What fits?
according to my cross reference software these will fit yours.
Part # = 16001-1200
Part Description = CARBURETOR
Model Count = 5
KZ750-E1 80 750 750 STANDARD-4 STREET
KZ750-E2 81 750 750 STANDARD-4 STREET
KZ750-H1 80 750 750 LTD-4 LTD STREET
KZ750-H2 81 750 750 LTD-4 LTD STREET
KZ750-H3 82 750 750 LTD-4 LTD STREET
Part # = 16001-1200
Model Count = 5
