29mm jetting
- cam9281
03 Feb 2008 13:36 #192601
by cam9281
29mm jetting was created by cam9281
I have a 1977 KZ1000 LTD. The bike has stock airbox and stock exhaust pipes and engine is stock. I am putting a set of 29mm mikuni carbs on it. I'm not sure what pilot jet and main jet to use. Any information will be greatly appreciated.
- Sandy
- Fly High,Tony
- Thank you received: 13
03 Feb 2008 14:07 #192608
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic 29mm jetting
Welcome Cam.
Hey...first of all...are You SURE that the carbs are 29mm,and not 28's?
Can you post a picture of them for Us to look at?
I'm using 29mm smoothbores as well,but I'm also using a 4 into 1 pipe with pods,so my jetting will be different than yours.
1977 KZ1000 A-1
- Sandy
- Fly High,Tony
03 Feb 2008 14:48 #192614
by Sandy
1977 KZ1000 A-1
1977 KZ1000 A-1
- cam9281
04 Feb 2008 02:51 #192678
by cam9281
Replied by cam9281 on topic 29mm jetting
Thanks for the info Sandy. I can't post a picture of them, but they for sure are 29mm smoothbore carbs. The info you linked me sure seems like it would be pretty rich for the bike. I'm not sure.
- wiredgeorge
04 Feb 2008 06:05 #192699
by wiredgeorge
Replied by wiredgeorge on topic 29mm jetting
Suggest you start with #17.5 pilot jets and #115 main jets and clip jet needles to 3rd slot. Slots are counted top to bottom with top = #1. The air screws will be out 1/4 turn or less. Type VM22/210 pilot jets are used and normal Mik main jets. This is for stock airbox/pipes.
- cam9281
04 Feb 2008 18:39 #192792
by cam9281
Thanks wiredgeorge! I'll try that setup.
