Soaking parts in berrymans
- ran429
- Master of FREE rides!
31 Jan 2008 15:29 #192057
by ran429
Soaking parts in berrymans was created by ran429
How long can i soak my brass parts in berrymans carb cleaner?
Can i dissasemble the carbs and just leave them in the solution until i get the primary main jets in the mail?
how long is too long to soak everything?
Post edited by: ran429, at: 2008/01/31 18:30
- Spot
31 Jan 2008 15:59 #192066
by Spot
Good judgment comes from experience, which usually comes from bad judgment. - Will Rogers
Replied by Spot on topic Soaking parts in berrymans
I've never tried berrymans, but the carb cleaner I use has recommendations on the can. I use the gallon can type with a basket inside. If berrymans is different, the guidelines should still be the same. Check out the carb cleaner kits at the local auto parts store if there are no directions on your can.
For extra tough buildup, I pulled them out of the cleaner, wiped them off, and dipped them again at 1/2 the time.
- ran429
31 Jan 2008 16:15 #192070
by ran429
Replied by ran429 on topic Soaking parts in berrymans
i didnt have to pull them.
Changed fuel filters and the engine wasn't getting fuel.
There was tons of rust or old fuel chunks sitting in the fuel line ahead of the filter. I never cleaned the inside as i thought it was fairly nice in there.
Must have had buildup in the lower parts i couldn't see
I will be tanking my fuel tank and repainting it this spring i guess.
Brother in law has access to a metal treatment facility (works there) Heat treating, sand blasting and everything else.
Post edited by: ran429, at: 2008/01/31 19:16
- Bluemeanie
- Thank you received: 14
01 Feb 2008 09:29 #192185
by Bluemeanie
Replied by Bluemeanie on topic Soaking parts in berrymans
When I use to rebuild carbs way back when, I would grab basket and swish back and forth (kinda like washing machine) every 15min or so. I think it helps move things around.
- bountyhunter
- Thank you received: 337
01 Feb 2008 09:47 #192191
by bountyhunter
Replied by bountyhunter on topic Soaking parts in berrymans
ran429 wrote:
The solvent should not hurt brass, but may dissolve plastics. I have left bolts and gun barrels to soak for weeks to get burned on carbon free.
how long is too long to soak everything?<br><br>Post edited by: ran429, at: 2008/01/31 18:30
- 76 LTD
03 Feb 2008 18:28 #192642
by 76 LTD
Replied by 76 LTD on topic Soaking parts in berrymans
I have left brass and aluminum parts in carb cleaner for weeks at a time.it wont hurt the parts but be sure you remove any plastic or rubber or you will have a nasty mess to clean up.
