CARB Needed
- keithnra
- keithnra
- 78kz650b
Mine-05' Ducati S4R
Wifes- 78' KZ650B
02' Harley FXDL Custom
- keithnra
- SLEEPER650
- Thank you received: 2
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
- Thank you received: 2098
i am looking for i 29mm smoothbore carb for a 78 kz 1000. One of my jetblocks are stripped out and i only need that part but will buy the whole carb.
One of my jetblocks are stripped out -- does this mean only that the small threaded hole in the bottom of the jet block is stripped, or something more serious?
The little screw going into the small threaded hole in the bottom of the jet block is mostly for positioning the jet block in correct orientation inside the bore and also holding the thin paper gasket in the correct position (if I'm remembering correctly).
The little screw is not intended to tightly hold the jet block against the bottom of the bore. If over-tightened (meaning tightened much at all), the jet block becomes slightly tilted (like the Leaning Tower of Pizza) and begins scraping against the throttle slides (not a good thing). Note that the screw hole is not centered in the jet block bottom.
Am wondering if a tiny dab of JBWeld into the stripped hole could afford enough grip whereby the little screw could hold the jet block in place without hardly any tightening at all.
Seems there would be no harm in trying. When found, a new replacement jet block is very expensive.
Good Luck!
P.S. Am trying to add some info about a possible source, if not already known.
Ian Williams Tuning (Australia) lists this part (also called Venturi Block)
002-500
VM29/10 JET BLOCK
$120.00
Website
Ian Williams Tuning
Contact info
Email, etc.
Have never dealt with them, but it's an interesting website with some good info and parts diagrams.
www.iwt.com.au/mikparts2.htm
www.iwt.com.au/
- wiredgeorge
My company is attempting to figure out a way to repair stripped jet blocks. Will make an announcement if we figure this out. One of the problems is lack of material for an insert and the insert will need to have unusual thread pitch which you just can't buy off the shelf somewhere.
The problem is caused because the thread is very shallow and there isn't much thread and if the needle jet is overtightened a bit, the thread will just let go. There isn't much money to be made repairing the things due to low volume of the carburetor type but there are a LOT of smoothbores out there that could use this repair.
You CAN fix the problem by JB Welding the needle jet in place. You just wouldn't be able to remove it again and I don't think that is a great way to repair the problem.
- keithnra
- wiredgeorge
- keithnra
- Sandy
- Fly High,Tony
- Thank you received: 13
The only reason I DIDN'T buy new ones,is because at that time,they weren't available,even through Sudco.
I do plan on getting a set of factory ones,so the next time I have to pull the carbs apart,I'll be able to replace them with nice new ones.(yippee)
I made them out of writing-paper...soaked the paper in oil first, and used one of the originals to trace and cut from.
Like I said...at least 3 seasons now,and no problems.
But hey...if they're available,get them.Don't go through the hassles that I had to.
1977 KZ1000 A-1
- keithnra
